width50%
The V-Ray Enmesh modifier 'coats' an object’s surface with a repeating pattern of a rendered geometry that follows the UVW space of that geometry.
width5%
width45%
Image Removed
HTML
<iframe width="360" height="655" src="https://www.youtube.com/embed/IOaEByQpgoo" title="Enmesh rendering on V-Ray GPU (Rhino)" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
UI Paths
width15%
width35%
||V-Ray Asset Editor|| > Geometries (right-click) > Enmesh
||V-Ray Asset Editor|| > Create Asset (left-click) > Geometries > Enmesh
width5%
width30%
||V-Ray Objects Toolbar|| > Make Enmesh from the selection (left click)
||V-Ray Objects Toolbar|| > Remove the Enmesh properties form the selection (right click)
Rhino Menus Ribbon
||V-Ray|| > Objects > Convert to Enmesh
width15%
Creating V-Ray Enmesh
width50%
V-Ray Enmesh is created with two types of objects – Base objects and Reference objects (Patterns), which are used to replace the Base object's surface.
UI Text Box
typetip
You can also create Enmesh from the Asset EditorGeometry Enmesh and use the Apply to Selection context option.
width5%
width20%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/6FEdPSwQHIA" title="Creating V-Ray Enmesh in Rhino" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
width60%
Add objects Add scene objects that will replace the base object's surface.
Spacing X Determines the distance between the items along X axis measured in project units.
Spacing Y Determines the distance between the items along Y axis measured in project units.
Spacing Z  Determines the distance between the items along Z axis measured in project units.
UI Text Box
typenote
Negative values can be used for clipping the items.
Tiling U  Determines how many times the element is repeated in U direction.
Tiling V Determines how many times the element is repeated in V direction.
Height (%)  Scales the height of the replicated element.
Height offset (%)  Determines the elements' offset from the Base surface in relation to the element's height.
Offset U  Offsets the elements in the U direction.
Offset V  Offsets the elements in the V direction.
Random Offset U  Applies a random offset of the elements in the U direction.
Random Offset V Applies a random offset of the elements in the U direction.
UI Text Box
typenote
The offset values are in relation to the reference object's size
Rotation  Determines the rotation of the pattern elements.
Random Rotation  Rotates each element with a random angle ranging between 0 and the +/- Random Rotation value.
Use Rotation Step  When enabled, Random rotation is based on a 360/X where X is Steps count. For example, if Random rotation is set to 4, the pattern mesh is randomly rotated on a 90 degrees step (360/4) - 0, 90, 180, 270, 360 (0). If there is also a Rotation set, for example to 30 degrees, there is a 30 degrees offset - 30, 120, 210, 300, 390 (30).
UI Text Box
typenote
Random Offset and Random Rotation are not compatible with U and V Tiling values less than 1.
Options
Map Channel  Determines the mapping channel to be used when positioning the elements.
Use Items UVs  When disabled the base mesh UV mapping (texture placement) overrides the UVs of the items. Each item (pattern object) will inherit the UV coordinates of the point of the base mesh that lies below.
When enabled the original item UVs are used instead.
Use Items Mtl IDs  When enabled the original item material IDs are used. When disabled the base mesh IDs override the IDs of the items. Each item will inherit the ID of the face of the base mesh that lies below.
width5%
width35%
Examples
Reference Object used for building a pattern:
The geometries which are repeated are the parts of the Reference Object which are inside of the Bounding Box. By default the Bounding Box encloses all the Reference Objects added.
The Bounding box can be changed with the Spacing X, Spacing X and Spacing Z parameters. Positive values for Spacing increases the Bounding Box of the Reference Objects
and this way creates distance between the items. Negative values clip away parts of the Reference objects.
width5%
width39%
width51%
width5%
width25%
width50%
Tiling
width25%
width25%
width50%
Image slider
Panel
borderStylenone
Tiling = 5, Height = 100%, Height Offset = 80%
Panel
borderStylenone
Tiling = 10, Height = 50%, Height Offset = 80%
Panel
borderStylenone
Tiling = 15, Height = 50%, Height Offset = 80%
width25%
width5%
width45%
Spacing
width45%
Rotation
width5%
width5%
width45%
Image slider
Panel
borderStylenone
Spacing X and Y = 0
Panel
borderStylenone
Spacing X and Y = 0.5
Panel
borderStylenone
Spacing X and Y = 3
width45%
Image slider
Panel
borderStylenone
Rotation = 0
Panel
borderStylenone
Rotation = 90
Panel
borderStylenone
Rotation = 90, Use Rotation Step = on, Random Rotation = 4
width5%
width5%
width45%
Randomization with Multi-Sub Texture: Get ID from set to Random by Instance ID
A material with a Multi-Sub texture in the Diffuse slot is assigned to the Enmesh Host geometry. The Gamma Variation of the texture is randomly changed on each Enmesh Instance.
width45%
Randomization with Multi-Sub Texture: Get ID from set to Random by Face Material ID
A material with a Multi-Sub texture in the Diffuse slot is assigned to the Enmesh Host geometry. The Gamma Variation of the texture is randomly changed on each Face material ID of the Reference object. Use "Items Mtl IDs" of the Enmesh needs to be enabled for this option
width5%
width5%
width45%
Image slider
Panel
borderStylenone
Gamma Variation = 0
Panel
borderStylenone
Gamma Variation = 0.05, Seed = 4
Panel
borderStylenone
Gamma Variation = 0.05, Seed = 1
width45%
Image slider
Panel
borderStylenone
Gamma Variation = 0
Panel
borderStylenone
Panel
borderStylenone
Gamma Variation = 0.05, Seed = 5
width5%
width5%
width45%
Randomization with UVW Placement
The Enmesh Use Items UVs needs to be enabled in this case.
width45%
Use Items UVs
width5%
width5%
Image slider
Panel
borderStylenone
UVW Placement = Stochastic Tiling
Panel
borderStylenone
UVW Placement = By Instance, Seed = 3
Panel
borderStylenone
UVW Placement = By Instance, Seed = 4
width45%
Image slider
Panel
borderStylenone
Use Items UVs = On
Panel
borderStylenone
Use Items UVs = off, Repeat U/V (of the texture) = 1
Panel
borderStylenone
Use Items UVs = off, Repeat U/V (of the texture) = 3
width5%
Footnotes
Fancy Bullets
typecircle
  • VRayEnmesh is incompatible with render-time created geometry like Displacement, Fur and Scatter.
