Section | |||||||||||||||
Input Parameters
Caustics Subdivisions (Integer) – Determines the number of caustic photons emitted from the light source. Lower values mean more noisy results, but renders faster. Higher values produce smoother results but take more time.
UI Text Box | ||
Caustics can be rendered only when rendering the scene in Rhino (with Caustics enabled in Asset Editor) from the "Render in Project" component. |
Output Parameters
Add Light (Generic Data) – Light output that can be connected to a Render.
