When using the Bucket sampler, the Autosave Interval (min) option isn't available.
Image Modified
If by any chance you disable the Save Image option, you will receive an error when you start a resumable render.
Image Modified
  • Start rendering your image. The passes calculate for a Progressive render or the buckets begin to drop for a Bucket render. The render can be stopped at any point in time and V-Ray will be able to use the .vrimg or .vrprog files to resume the render later.
  • Select Bucket or Progressive rendering type from Render Settings LOP > V-Ray tab > Image Sampler tab.
  • Set the Non-Hydra Output from Render Settings LOP > V-Ray tab > Output tab. Append .vrimg.
  • Set the Output File Name from Render Settings LOP > V-Ray tab > Output tab. Append .vrprog or .vrimg depending on whether you’ve selected Progressive or Bucket rendering.
  • In the same tab, enable Resumable Rendering.
  • If using the Progressive sampler, it is highly recommended to enable the Autosave Interval by setting it higher than 0. This saves partial files that can be used and helps prevent losing the render progress if Solaris crashes and a .vrprog file was not created/updated.
  • Set V-Ray as the renderer in the USD Render ROP and enable the MPlay Monitor from the LOP's Husk tab.
Image Modified
UI Text Box
typetip
Enable the Delete Resumable Files on Success option to automatically delete any resumable files after the frame is completed successfully.
