This tutorial covers the steps to creating realistic fire with V-Ray for 3ds Max.
Section | |||||||||||||||||||||||||||||||||||||
Preparations
To use VRayVolumeGrid you need a suitable input file with a proper volumetric data in it. In this case you need a fire simulation.
To learn how to create such a file using Chaos Phoenix, follow the steps from this tutorial: MAKING OF FIRE TRAILS
Creating the VRayVolumeGrid
Positioning and Scaling the VRayVolumeGrid
Adjust the VRayVolumeGrid Parameters
Final Result
The final image is rendered with Bucket image sampler and the following settings: Min subdivs set to 1, Max subdivs set to 24, Light cache is 2500, and Noise threshold - 0.01.
