V-Ray Enmesh
V-Ray Enmesh is ideal for creating intricate panels, fences, fabrics, and so much more, and it uses much less memory than displacement or copying by hand. The V-Ray Enmesh modifier will coat the object's surface with a repeating pattern and will follow the Surface UVW space of that geometry.
