Finite dome
With the new finite dome you can have full control over the Dome light and blend your models into any HDRI environment. The new flexible ground projection capabilities of the V-Ray Dome Light allow you to make an object appear to be set in place in an HDRI environment, while also allowing camera zooming, rotation, and more.
