Phoenix Simulator | node – Determines which Simulator will be used to read the fluid data from.
Group – Specifies a thinkingParticles Group to place the newly generated particles into.
Rate | rate_type[0],rate_percent – A Sets a multiplier for to the base birth probabilityrate of the operator.
Rate (max prt/s) | rate_type[1], rate_per_sec – A multiplier for the birth probabilitySet a limit to the number of particles born per second.
Seed | seed – An initial value for the random numbers generator.
Lifespan | lifespan – The average lifespan of the generated particles. When Variation (%) is set to 0, all particles have exactly the same lifespan.
Variation (%) | lifespan variation – Allows you to vary Varies the lifespan of the generated particles. If set to 100%, the shortest living particles will have a live twice shorter than average, and the longest living particles will have double the average Lifespan.
Size | size – The average Size of the generated particles. When Variation (%) is set to 0, all particles have exactly the same Size.
Variation (%) | size variation – Allows you to vary Variesthe Size of the generated particles. If set to 100%, the smallest particles are two times smaller than average and the largest particles will have double the average Size.
Mass | Mass – The average Mass of the generated particles. When Variation (%) is set to 0, all particles have exactly the same Mass.
Variation (%) | mass variation – Allows you to vary Varies the Mass of the generated particles. If set to 100%, the lightest particles have Mass two times lower than average and the heaviest particles will have double the average Mass.
Combine | combine – The Sets the method used to combine the results of the diagram diagrams for Temperature, Smoke and Speed.
Add – The values are added. Multiply – The values are multiplied. Biggest – The biggest value is selected.
Temperature/Smoke/Speed/Fuel | use_t, use_s, use_v, use_f – Diagrams representing the birth density based on each source channel.
Reset – Resets the corresponding diagram with its default content.
