width50%
Enable – This checkbox enables the Cloud system for the Sky.
Amount – This value is the amount of the main clouds (stratus, cumulus, cumulonimbus). A value equal to 0% means there are no such clouds in the sky, while a value equal to 100% means the sky is full of these clouds.
Variety – This value randomly changes the appearance of the main clouds.
Cirrus amount – This value sets the amount of cirrus clouds (clouds high in the sky). A value equal to 0% means that no cirrus clouds are visible, while a value equal to 100% means the maximum amount of cirrus clouds in the sky.
Phase – This value determines minor perturbation of the clouds to simulate their change in time.
Seed - Generates new clouds when the value is changed.
Density scale - Controls the density appearance of the main clouds. Value A value of 1 means no additional scaling, ; increasing the value leads to denser clouds , while decreasing the value results in lower-density clouds.
width5%
width45%
width5%
width40%
Clouds - Cirrus amount
Before after
afterLabelCirrus amount = 75%
beforeLabelCirrus amount = 25%
Panel
Panel
width5%
width40%
Clouds - Phase
Before after
afterLabelPhase = 50%
beforeLabelPhase = 0%
Panel
Panel
width10%
Clouds Position
section
width5%
width50%40%
Clouds – Density scale
Image slider
Panel
borderStylenone
titleDensity scale = 0.1
Image Added
Panel
borderStylenone
titleDensity scale = 0.5
Image Added
Panel
borderStylenone
titleDensity scale = 1 (default)
Image Added
Panel
borderStylenone
titleDensity scale = 10
Image Added
width5%
width40%
Clouds – Seed
Image slider
Panel
titleSeed = 0 (default)
Image Added
Panel
titleSeed = 5
Image Added
Panel
titleSeed = 10
Image Added
Panel
titleSeed = 50
Image Added
width10%
Clouds Position
width50%
Altitude [m] – This value controls the altitude (measured from the ground) at which the main cloud starts
Altitude [m] – This value controls the altitude (measured from the ground) at which the main cloud starts.  Measured in meters.
Height [m] – This value controls the height (thickness) of the main clouds. Increasing this value leads to heavier clouds, while decreasing it results in lighter (more transparent). Measured in meters.
Offset X [m] – This value offsets clouds on the X-axis.  Measured in meters.
Offset Z Height [m] – This value offsets clouds on the Z-axis. Measured in meters.
width5%
width45%
Image Removed
Offset Z [m] – This value offsets clouds on the Z-axis. Measured in meters.
width5%
width45%
Image Added
width5%
width40%
Clouds Position - Altitude [m]
Before after
afterLabelAltitude = 5000m
beforeLabelAltitude = 1000m
Panel
Image Removed
Panel
Image Removed
width5%
width40%
Clouds Position - Height [m]
Before after
afterLabelHeight = 1000m
beforeLabelHeight = 500m
Panel
Image Removed
Panel
Image Removed
10%
width
width5%
width40%
Clouds Position -
Offset X
Altitude [m]
Before after
afterLabelOffset X Altitude = 1000m 5000m
beforeLabelOffset X Altitude = 0m 1000m
Panel
Image RemovedImage Added
Panel
width5%
width40%
Clouds Position -
Offset Z
Height [m]
Before after
afterLabelOffset Z Height = 1500m 1000m
beforeLabelOffset Z Height = 0m 500m
Panel
Panel
width10%
Density scale
width20%5%
width60%40%
Clouds Position - Offset X [m]
Before after
afterLabelOffset X = 1000m
beforeLabelOffset X = 0m
Panel
Image Added
Panel
Image Added
width5%
width40%
Clouds Position - Offset Z [m]
Before after
afterLabelOffset Z = 1500m
beforeLabelOffset Z = 0m
Panel
Image Added
Panel
Image Added
Image slider
Panel
borderStylenone
titleDensity scale .1
Image Removed
Panel
borderStylenone
titleDensity scale 1 (default)
Image Removed
Panel
borderStylenone
titleDensity scale 5
Image Removed
Panel
borderStylenone
titleDensity scale 10
Image Removed
width20%10%
Contrails
width50%
Enabled – This enables the use of contrails for the sky.
Plane count – Controls how many planes are simulated to create contrails.
Time – Controls the simulation of time - increasing time moves planes along their travel direction. Increasing this property by larger values can be used as a random seeding of the planes positions.
Strength – Determines how many contrails are visible in the sky.
Distortion – Determines how much contrails are distorted. A value of 0% gives contrail lines without any distortions, while a value of 100% results in a maximum amount of distortion.
Offset X [m] – This value offsets contrails on the X-axis. Measured in meters.
Offset Z [m] – This value offsets contrails on the Z-axis. Measured in meters.
width5%
width45%
