Enabled – Allows you to turn on and off the sunlight.
Size – Makes the shadows softer/sharpen.
Intensity – Specifies an intensity multiplier for the Corona Sun.
View size – Allows you to adjust the Corona Sun object's viewport representation. This value won't affect any other parameter.
Textured – When enabled, there are subtle color differences towards the borders/horizon. Enabling this option can slow down the rendering and produces no visible differences, except when the sun is viewed directly in detail, so there is usually no need to enable it. When disabled, the sun disc has uniform color on its entire surface.
width
5%
width
45%
width
50%
Use color from sky – Changes the Corona Sun color, depending on the position of the sun.
Color – Allows selecting specific colors for the light emission. Note that the chosen color will now also affect the color of Chaos clouds respectively.
Temperature – Adjusts the Corona Sun color temperature according to the Kelvin Temperature Scale.
Rotation – Sets the orientation (clockwise) of the Sun using the vertical axis.
Angle – Sets the sun's angle from the horizon to the zenith.
Direction – These parameters set the position of the sun.
width
5%
width
45%
width
50%
Visible directly – When enabled, this makes the Corona Sun directly visible to the camera.
Visible in reflections – When enabled, this makes the Corona Sun directly visible in reflections.
Visible in refractions – When enabled, this makes the Corona Sun directly visible in refractions.
Generate caustics – Enabling this option allows for generating caustics.
Visible in editor – When disabled, hides the object in the viewport.
Apply shadows from clouds – When enabled in combination with the clouds from the Corona Sky, the sun casts shadows from the clouds.
