This article explains what is the Corona Camera tagTag, its settings, and how to use it.
Section | ||||||||||
When using the Corona Camera tagTag, you'll be able to individually control the exposure, tone mapping options, DOF, and other values. You can enable or disable the override checkbox for each camera option. You can find the Corona Camera object (which is a C4D camera + a Corona Camera tagTag) under the Corona menu.
Section | ||||||||||||||||||||||||||||||||
The following renders are from exactly the same scene. The volume is made from a simple water plane with displacement and surrounding walls.
Tone mapping
Bloom and glare
Sharpening
Depth of field (DOF)
Advanced bokeh effects
Projection
