Responsivegridmacro
VAlignmentstart
Columns3width1000px
Columnsrepeat(2, 1fr)
ClassRespColumnsHeader
Columns2width1450px
CSS Stylesheet
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
div
classRespColumnsHeader
Official Release
Date - October 13, 2022
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage, 1.8.2 Build
urlhttps://download.chaosgroup.com/?platform=47&product=63
Align
alignright
Responsivegridmacro
VAlignmentstart
Columns3width1000px
Gap20px
ClassRespColumns3
div
classRespColumns3
New Features
NVidia AI Denoiser
Fancy Bullets
  • Option to denoise only final sampling pass in offline rendering.
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Tools+Menu
Modified
Environment
Fancy Bullets
  • Implemented a default Vantage sun so Physical Sun and Sky option is available in the Environment mode drop-down
UX/UI
Fancy Bullets
  • Added "Always On Top" button in the top toolbar and shortcut (Ctrl+Alt+T).
    UI Button
    colorblue
    iconinfo
    titleDetails
    urlhttps://docs.chaos.com/display/LAV/Toolbars
  • Added outlines to rollouts.
  • Improved the snapping behavior for manipulation gizmos.
  • Added sliders below parameters with soft range and CTRL(snaps to 1/1000 of the slider's soft range value), SHIFT(snaps to 1/10 of the slider's soft range value) and CTRL+SHIFT(snaps to 1/100 of the slider's soft range value) modifier keys for finer control.
  • Synchronized value defaults and ranges between Vantage UI and "Render animation via Live Link" dialog in 3Ds Max .
Path resolver
Fancy Bullets
  • Improved path resolver now searches every subfolder next to the imported file, for assets.
Motion blur
Fancy Bullets
  • Reduced artifacts from motion blur
Denoiser
Fancy Bullets
  • Improved Vantage denoiser result in refraction and flickering object edges.
  • Improved refraction quality when switching between Vantage and NVidia AI in Combined denoiser mode.
  • Improved reflection detail with NVidia AI denoiser.
Auto-exposure
Fancy Bullets
  •  Improved auto-exposure that accumulate samples in dark areas (single GPU only).
Fixes
Rendering
Fancy Bullets
  • Visual popping of textures with "Dynamic textures" option enabled.
  • Wrong blending of the sun disk with the ground albedo.
  • Wrong alignment of the sky texture's horizon line .
  • Temporal denoiser and postprocessing passes breaking with dynamic textures.
  • Reduce flickering being used when disabled in High quality rendering.
Auto-exposure
Fancy Bullets
  • Crash when starting an offline render with "Auto exposure" enabled on systems with 2 GPUs.
Command line
Fancy Bullets
  • Crash when rendering with -denoiser=0.
Fancy Bullets
  • Hang when the Live Link drops during a sequence rendering.
  • Random abort while rendering sequence using "Render animation using Chaos Vantage".
  • Live Link in 3ds Max doesn't start with the first click on the Start/Stop button.
  • Distributed rendering in 3ds Max to always deactivate when the Live Link stop button is pressed.
Motion blur
Fancy Bullets
  • Not applying to moving objects when using "Render animation using Chaos Vantage".
  • Not rendering in "Render animation using Chaos Vantage" Maxscript.
Import/Load
Fancy Bullets
  • Errors caused by loading empty string texture filenames.
  • Scene animation range one frame shorter when loading .vantage file.
UX/UI
Fancy Bullets
  • UI bug when switching between 'Focal length' and 'Field of view'.
  • Transform manipulation and snapping windows not being disabled in Live Link.
  • Inconsistent spinner value changes on secondary monitor .
  • Wrong rotation range for transform type-ins.
  • Chaos Vantage starting at invalid coordinates when monitor layout changes between sessions .
Render elements
Fancy Bullets
  • Missing velocity in EXR.
  • Alpha getting lost in EXR when motion blur is enabled.
