This page provides information on the Corona UVW Randomizer Map.
width
50%
Textured objects often show obvious repetitions, which instantly give away that the scene is computer-generated. You can use the Corona UVW Randomizer Map to quickly randomize textures on multiple objects or object parts, making the image appear more realistic.
The UVW Randomizer Map allows you to apply random offset, rotation, and scaling to textures and procedural maps assigned to different objects, or even to a single object. The way it works is similar to the Corona Multimap. For example, you can randomize a wood texture applied to a set of planks so that each plank has a different look in your final render. You can also apply a blending effect to the randomized texture tiles, which makes them appear even more natural.
To enable the UVW randomization, plug any texture (be it a bitmap or a procedural map) into the UVW Randomizer Map input slot and then plug its output into any material property. You can then adjust the texture transformations and other options to the desired values. You can use the UVW Randomizer Map with any material property, including grayscale bump maps, RGB normal maps, and displacement.
UI Text Box
type
note
The effect of the Corona UVW Randomizer Map is not visible in the viewport preview.
