This page provides information on the Corona Bump Converter Map, its settings, and usage.
Floatingpagetoc |
By default, 3ds Max treats bump maps differently than "regular" RGB maps, so some maps do not work correctly as inputs to bump mapping. The Corona Bump Converter resolves this, allowing you to use any map as an input to the bump map channel in a shader.
