This page provides information on the Corona Normal Map, its settings, and usage.
Section | |||||||||||||||
How to find out what settings to use?
There are two ways to find out which settings are correct:
- Get reliable information about the normal map you are using (e.g. it could be included in a readme file supplied with the bitmap).
- Trial and error approach.
Sometimes it is easy to imagine what the normals should look like (in case of a spherical or pyramidal pattern), but sometimes it may be harder (in case of a chaotic, organic pattern).
Examples
Section | |||||||||||||||||||||||||
