Camera clipping enabled and "Extend view" set to 5 meters
Image RemovedImage Added
With camera clipping disabled, the ground plane is fully covered with the scattered instances. When camera clipping is enabled, it limits the instances to the visible area only. The Extend view option can be used to expand the area where the instances are visible. This is useful, for example, to make sure that trees growing close to the camera are not removed.
UI Text Box
type
info
In this example, If you ever observe the colors of the trees change between different renders, because when using the Corona Multimap, the distribution of colors depends on the current number of instances. Since we are changing the number of instances by removing some of them, the Multimap produces different "patterns"instances changing when enabling the camera clipping option, make sure that in your Scatter object, under its Scattering rollout, you have the Legacy mode checkbox disabled. Enabling this checkbox reverts to the behavior of older Scatter versions, which can cause the color changing issue.
