Section | |||||||||||||||
Corona VFB Buttons
Button | Description |
Saves the render element currently displayed |
in |
the VFB using a specified file format. | |
Press and hold the "Save" button: Save all – Saves each render element as a separate file using a specified file format. Save CXR –Stores all the information from the VFB (all render |
elements, including the LightMix, tone mapping, denoising data, etc |
.) inside a single CXR file. | |
Copies the content of the Corona VFB to the native 3ds Max VFB. | |
Copies the render element currently displayed |
in the VFB to the clipboard. Useful for pasting the content of the VFB into other apps without |
saving the file. |
Forces a VFB refresh. Useful mostly when using very high VFB |
update interval values. | |
Clears the VFB. | |
Toggles visibility of the side panel. | |
Toggles render region drawing mode. Left-click and hold to draw a region. Drag region border with Control key to |
enable "fuzzy regions". | |
Allows to pick object from VFB. Left-click to select an object. Right-click to select and object or set camera focus to the selected point in scene. Works also in interactive rendering. | |
Selects the render element to be displayed in the VFB. | |
Zooms in. | |
Zooms out. | |
Resets zoom. | |
Stops |
the rendering process without discarding any additional data or post-rendering actions. This is the same as the "Stop" button in the 3ds Max rendering dialog - when denoising is enabled, pressing this button stops the rendering process and proceeds to denoising. | |
Press and hold "Render" button: Render – Starts render. Start IR –Starts Interactive |
Resume last – |
Resumes last render. Resume file – |
Resumes rendering based on a previously saved CXR file. |
Post Tab
