Section | |||||||||||||||||||||||||||||||||
Size – Increases/decreases bloom and glare size. Bloom intensity – Increases/decreases bloom intensity. Glare intensity – Increases/decreases glare intensity. Threshold – Controls the minimum brightness which is considered for the Bloom and Glare effect. Increasing the threshold applies Bloom and Glare only to the brighter pixels. Reducing it allows the Bloom and Glare effect to be applied to pixels that are less bright. Color intensity – Controls how saturated the Bloom and Glare effect is. Higher values mean higher saturation. Color shift – Changes the hue of the coloring added to the Bloom and Glare effect. Streak count – Defines the number of streaks for the glare effect. Rotation – Rotation of the glare effect in degrees. Streak blur – D ecides whether the glare streaks should be sharper or more blurry. Custom aperture – Launches an editor which can be used to fine-tune advanced Bloom and Glare options. Sharpening/BlurringSharpen amount – The value that is used to control sharpening. Sharpen radius – Defines the sharpness radius. Blur radius – Defines the radius of blur. DenoisingDenoise amount – The main value that is used to control denoising. It blends between the original (noisy) image and the fully denoised version of the image, where 0 is the original image and 1 is the purely denoised version.
