Display mode– Selects how to display scattered instances in the viewport. Affects viewport performance. Available display modes are:
None – Instances are not displayed at all. Dot – Each instance is displayed as a single dot. Box – Each instance is displayed as a solid box. Wire box – Each instance is displayed as a wire box. Full – Each instance is displayed as the full mesh.
Max instances– Maximum number of scattered instances being displayed in the viewport. When this limit gets exceeded, some instances are randomly hidden. If increasing this number would display more instances, the label is colored.
Immediate updates – Forces re-computation of the scattering.
width
5%
width
45%
Edge Trimming
width
50%
The Scatter Edge Trimming feature allows you to trim scattered instances consisting of multiple mesh elements so that they stay within the boundaries of the distribute-on objects.
To learn more about it, please visit the following:
