width33%
Material Override is off
width33%
Single Object's material is overridden
width33%
Multiple Objects' materials are overridden
width1%
UI Text Box
colorlight-cyan
iconinfo
typeinfo
In V-Ray for Houdini, a Referenced Shader VOP node is now available. It can be used to (as its name implies) reference another node – when you do this, you get the entire shading network up to the node that is being referenced. This means that you could reference your final material and use that as an override material, applying e.g. a Render Stats after it and assigning it to the geometry. This works for any VOP node, e.g. textures, displacement, etc.
UI Text Box
colorlight-yellow
iconwarning
typenote
The overrides can affect the displacement as well – there is a toggle that specifies whether the original object’s displacement is used, or the one coming from the override material. This has two major uses:
Fancy Bullets
typecircle
  • Disabling the Displacement for an object by saying Use Displacement from Override Material and not supplying any displacement in the override mtl.
  • Changing the Displacement tessellation by applying a new displacement with lower quality settings.
