This page gives information about the Chaos Cosmos Browser in Houdini and Solaris.
width55%
Chaos Cosmos Content System delivers a 3D content library of high-quality 3D content selected from the rich V-Ray ecosystem. It allows V-Ray users, from their respective V-Ray products, to browse, place, and render 3D assets in their projects. The asset categories span across Furniture, Accessories, People, Vegetation, Vehicles, HDRIs, and more. In addition, the assets work seamlessly in the different Chaos renderers (V-Ray, V-Ray GPU, Vantage, Corona, and Vision) and host apps (Houdini, 3ds Max, Cinema 4D, Maya, Revit, Rhino, and Sketchup).
Chaos Cosmos Browser is part of the installation of V-Ray and does not require any other specific actions. You can access the downloadable content of the Chaos Cosmos Platform from within the host platform after the V-Ray installation is completed.
UI Text Box
typeinfo
Chaos Cosmos is now supported in Houdini under Mac OS, starting with Houdini version 20.0.506. Cosmos Mac OS support for the ARM architecture is planned for the future but currently not available.
UI Text Box
typeinfo
The latest version of Chaos Cosmos Browser is supported on macOS 10.14 and newer; earlier versions of macOS support Chaos Cosmos Browser 2023.07.10.
width5%
width40%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZlspiGDS66s" title="V-Ray 6 for Houdini — Bring your environments to life with Chaos Cosmos" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
width45%
The Enmesh-Pattern category includes Enmesh patterns that can be applied to the geometry in the scene.
When an Enmesh asset is imported, a pattern is created in the obj network. Inside the pattern node, a mesh object can be created to receive the pattern.
If an object is already selected, the mesh is applied directly to the selection.
The imported pattern can be edited as a V-Ray Enmesh node of the underlying geometry.
For more information on Enmesh, see the How to Add V-Ray Enmesh tutorial.
width5%
width50%
V-Ray Cosmos Downloader
If you open a scene that contains Chaos Cosmos assets which are no longer present on the local machine, you can download them from the V-Ray Cosmos Downloader. The downloader is accessible from the V-Ray menu > Cosmos Downloader.
Example
This example shows a scene without and the same scene using Chaos Cosmos assets.
