Normals filtering – Determines how normal and bump maps are filtered:
None – No filtering is applied to normal and bump maps, providing high accuracy but potential noise and flickering.
Linear – Normal and bump maps are filtered linearly, just like other map types, potentially affecting material appearance with varying camera distance and render resolution.
Roughness Modulation – Utilizes linear filtering for normal and bump maps while also adjusting material roughness to maintain consistent material appearance regardless of camera distance and render resolution. Default filtering method in Corona 11 and newer.
Roughness mode – Determines whether roughness or glossiness mode is used as a default one in the Corona Physical Material. Note that this setting only influences newly created materials.
IOR mode – Determines whether IOR (Index Of Refraction) or Disney Specular mode is used as a default one in the Corona Physical Material. Note that this setting only influences newly created materials.
width
5%
width
45%
Image RemovedImage Added
Interactive Rendering (IR)
width
50%
Enable devel/debug mode – Enabling this checkbox shows a new tab in the Render settings with truly experimental, unfinished, and debug features. Only enable this if the Chaos staff requests it.
Enhanced OpenGL preview of Corona materials – Enabling this checkbox improves the material previews in the material editor. This checkbox is currently disabled as it is a legacy feature and it is no longer required in recent host app versions.
Open license server configuration – Launches the Chaos license settingsdialog to manually set specific parameters in case the License server is installed on a different computer.
About & licensing – Launches the About dialog that shows the installed Corona version, installed Cinema 4D version and additional information.
