width45%
V-Ray 7 includes:
  • Gaussian splats
  • Interactive virtual tours
  • Material override and presets
  • Cosmos asset variations
  • and more!
Official release
Date: Feb 26Mar 17, 2025
Build: V-Ray 7, hotfix 2 3 (7.00.0203)
UI Button
colorblue
icondownload
titleDownload V-Ray 7 for SketchUp
urlhttps://download.chaos.com/?platform=56&product=47
width5%
width50%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/zZLErsbI18o?si=UvSRjFU8cqMRGOyD" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Expand
titleRELEASE NOTES FOR V-RAY 7, HOTFIX 23
V-Ray 7, hotfix
2
3 (7.00.
02
03)
Official release
Date - Feb 26Mar 17, 2025
Improvements & Bug Fixes
  • An issue with migrating legacy projects is resolved. The fix primarily improves the migration of older projects and certain third-party asset libraries, such as Laubwerk’s
  • An issue where Swarm tags are updated unexpectedly due to an unstable connection to the nodes has been resolved. Tags are no longer removed without user interaction
  • The default output path in the Export V-Ray Scene window is improved
  • The Update Result denoiser button is no longer incorrectly disabled in a specific situation
  • All file paths displayed in the UI are now right-aligned to ensure the file name remains visible
  • Refresh button is no longer incorrectly displayed in the Cosmos asset properties header when selecting a variant that is not yet downloaded
  • Added support for SketchUp 2025
  • Added support for the native PBR material properties in SketchUp 2025
  • Added support for the native Environments feature introduced in SketchUp 2025. Use the menu command Extensions / V-Ray / Apply SketchUp Environment to create a Dome light which is synced with the SketchUp Image-based lighting (IBL) map
  • A number of useful links are added to the V-Ray / Help menu - Chaos Academy, Chaos Forum, Support Request and Ideas Portal
  • An issue preventing V-Ray from being loaded when the Windows OS username contains special symbols is resolved
  • An issue causing the Dome Light texture position to reset when modifying the light’s intensity is fixed
  • A Custom Viewport Display bitmap texture is no longer set unnecessarily when migrating older scenes
  • An issue with the material appearance after resetting its color in the SketchUp material panel during interactive rendering is resolved
  • A number of issues related to Material Override activation during interactive rendering are resolved
  • An issue preventing interactive rendering update on Displacement asset deletion is resolved
  • An issue leading to a crash when rendering Linked Models from Enscape is resolved
  • The Firefly Removal option is now hidden while the GPU engine is selected and greyed out while Progressive rendering is used, indicating that it has no effect with these configurations
  • A number of tooltips are updated
  • An issue preventing the submission of vrscene files for Cloud Batch rendering is resolved
  • An issue causing the Max Subdivs value to double when switching between CUDA and RTX GPU engine options is fixed
  • An issue causing the output resolution of Cloud Batch render images to be incorrectly overridden is resolved
Thumbnailspagesettings
ThumbnailOverlayRectangleColour0,0,0
ThumbnailOverlayRectangleOpacity0.4
ThumbnailBGImageCornerRadius4px
ThumbnailBGImageHeight280px
ThumbnailSubTextSize12px
ThumbnailTextColourWhite
ThumbnailTitleTextSize18px
ThumbnailOverlayRectangleBottomPadding10px
