These shortcuts navigate through the VFB image. Please note that the VFB window must have the current focus for the shortcuts to have effect:
Description | Shortcut Key | Description||
Global | Show/hide history | H | |
Show/hide only layers tree | P | ||
Show/hide whole right panel | Ctr+L | ||
Toggle Full Screen | F11 | ||
VFB Settings | S | ||
History/Render View | Enable history A/B/C/D compare mode | E | |
Enable history A/B horizontal compare mode | Q | ||
Enable history A/B vertical compare mode | W | ||
Load the respective image from the new VFB history (1...9) | 1; 2; 3; 4; 5; 6; 7; 8; 9 | ||
Layers/Property Panel | Redo | Ctr+Y | |
Undo | Ctr+Z | ||
Layers | Delete a layer | Del | |
Message Log | Close Search | Esc | |
Find in Log | Ctr+F | ||
Find next | Return | ||
Find previous | Shift+Return | ||
Render View | Abort rendering | Esc | |
Copy current channel to clipboard | Ctr+C | ||
Flip horizontally | M | ||
Flip vertically | Shift+M | ||
Load image | Ctr+O | ||
Lock pixel info coordinates | L | ||
Pan image (up, left, down, right) | Up; Left; Down; Right (arrow keys) | ||
Switch to Alpha channel | A | ||
View blue channel | B | ||
View green channel | G | ||
View next channel | PgDown | ||
View previous channel | PgUp | ||
View red channel | R | ||
Zoom 100% | * ; Double-click left button | ||
Zoom in | + / = | ||
Zoom out | -/_ | ||
Zoom to fit | F | ||
Zoom in the rendered image | Ctrl+Shift+Left click | ||
Zoom out the rendered image | Ctrl+Shift+Right click | ||
Symmetric render region resizing | Alt+resize |
