This page provides detailed information about the Render Setup window.
 The Render Setup window allows you to specify render parameters for still, sequence, or batch rendering.
UI Text Box
typeinfo
 Set values and parameters are auto saved and will be used between sessions.
UI Path
To access the Render Setup window, go to:
width5%
width45%
 ||Tools menu|| > High Quality Render (Shortcut: Ctrl+R )
width5%
width45%
||Bottom toolbar|| > Hight Quality Render button (Vantage_Bottom_Bar_quality.PNG)
Render setup
Render output – Specifies the render output - a still or an animation sequence.
Tabs Container
directionhorizontal
Tabs Page
titleStill image
Camera
width60%
Camera enqueue mode – Sets the mode that specifies how cameras are added to the render queue when the Add to Queue(Vantage_RenderQueue_AddToQueue.png) button is clicked.
One – Adds only the cameras specified in the Camera dropdown to the render queue.
Group – Adds the specified group of cameras from the Camera dropdown list to the render queue.
All – Adds all scene cameras to the render queue.
Camera – Specifies the rendering camera from a list of available scene cameras or <current camera> position.
Scene state – Specifies a scene state from a list of available scene states to apply when rendering or to use the scene's current state when <chosen scene state>.
Camera type – Specifies the type of the camera to be used when rendering a snapshot.
Perspective – Sets the current scene camera to be used to render the snapshot.
Cube 6x1 – Sets the use of a Box camera with the cube sides arranged in a single row useful in generating cubic VR output.
Stereo Cube 6x1 – Sets the use of a Left/Right stereo Box camera with the cube sides arranged in a single row useful in generating cubic stereo VR output.
Spherical – Sets the use of a spherical camera with independent horizontal (FOV X) and vertical (FOV Y) FOV selection that is useful for generating latlong images for spherical VR use.
Stereo spherical – Sets the use of a spherical Left/Right stereo camera with independent horizontal (FOV X) and vertical (FOV Y) FOV selection and that is useful for generating latlong images for spherical VR use. The stereo strength can be adjusted by modifying the Eye dist parameter.
Orthographic – Sets the use of an orthographic camera with an Orthographic width.
FOV X – Specifies the horizontal field-of-view angle. Available only when Camera Type is set to Spherical or Stereo spherical.
FOV Y – Specifies the vertical field-of-view angle. Available only when Camera Type is set to Spherical or Stereo spherical.
Eye dist – Specifies the eye distance for which the stereoscopic image is rendered. Available only when Camera Type is set to Stereo Cube 6x1 or Stereo spherical.
Focus rotation – When enabled, the left and right views are rotated so that their focus points coincide at the distance specified by the Focus Distance parameter in the Camera tab. When disabled, the left and right views directions are parallel.
Top/Bottom – When enabled, the output layout for the views is Top(for left eye) and Bottom(for right eye). When disabled, the output layout is Left(for left eye) and Right(for right eye).
Orthographic width – Specifies the width (in scene units) of the orthographic camera. It controls how much of a scene the camera can see and has the same effect as zooming a perspective camera.
Auto-exposure – When enabled, exposure is automatically calculated. Set exposure in camera is ignored.
Motion Blur – Enables the rendering of motion blur for the rendered image with the settings set in Camera tab.
width5%
width35%
Resolution
width60%
Width – Sets the width of the rendered snapshot in pixels.
Height – Sets the height of the rendered snapshot in pixels.
Preset – Sets the render resolution from several predefined resolutions:
<from camera> – Sets the render resolution from the camera resolution in the Camera tab.
<current resolution>
– Sets the render resolution to the current core render resolution. Current core render resolution can be seen from the Rendering status tag in the status bar.
540p
(960x540); HD 720p(1280x720); 900p(1600x900); FHD 1080p(1920x1080); 1440p(2560x1440); UHD 4K(3840x2160); UHD 8K(7680x4320); PC Video(640x480); NTSC(720x486); PAL(720x576); 1K Super 35(1024x778); 2K Super 35(2048x1556); 4K Super 35(4096x3112); 8K Super 35(8192x6224); 1K Cinemascope(914x778); 2K Cinemascope(1828x1556); 4K Cinemascope(3656x3112); 8K Cinemascope(3656x3112); 16K Cinemascope(7312x6224); 1K DCP(1024x540); 2K DCP(2048x1080); 4K DCP(4096x2160); 8K DCP(8192x4320); 512 Square(512x512); 1K Square(1024x1024); 2K Square(2048x2048); 4K Square(4096x4096);
Aspect – Sets the aspect of the render resolution.
Lock aspect – When enabled, locks the Width value to the Height value. When changing the Height value, the Width changes proportionally according to the Aspect value.
width5%
width35%
Render
width60%
Samples – Specifies the samples per pixel for refining the image.
Quality – Sets the rendering quality based on 4 predefined presets:
Low – Sets the rendering quality using the following values:
GI – Off;
GI bounces – 1;
Reflection bounces – 2;
Refraction bounces – 4;
Coat – On;
Shading graph – Off;
Noise threshold – 0.5;
Opacity maps(clip) – Off;
Shading graph for glossy/GI – Off;
Medium – Sets the rendering quality using the following settings:
GI - On;
GI bounces – 2;
Refraction bounces – 8;
Coat – On;
Shading graph – On;
Noise threshold – 0.1;
High – Sets the rendering quality using the following settings:
GI – On;
GI bounces – 3;
Reflection bounces – 8;
Coat – On;
Shading graph – On;
Noise threshold – 0.05;
Opacity maps(clip) – On;
Ultra – Sets the rendering quality using the following settings:
GI – On;
GI bounces – 4;
Reflection bounces – 15;
Refraction bounces – 15;
Coat – On;
Shading graph – On
Noise threshold – 0.01;
Shading graph for glossy/GI – On;
Custom – Sets the rendering quality using the settings from the Render settings tab.
Light Cache – Enables Light Cache when rendering.
Keep Desktop Responsive – When enabled, reduces the effect on other applications while Vantage is rendering.
Denoiser – When enabled, applies denoising to the rendered image. It allows choosing between the NVIDIA AI denoiser or Intel Open Image Denoise.
NVIDIA AI – Vantage's integration of NVIDIA's AI-based denoising algorithm. The NVIDIA AI denoiser requires an NVIDIA GPU to work.
Intel Open Image Denoise – Vantage's integration of Intel Open Image Denoise.
Only final pass – Applies the denoiser only during the final pass. This greatly reduces render time when used with high Samples count.
width5%
width35%
Render Elements
width60%
Render Elements – When enabled, outputs render elements for use in compositing software. Specific render elements can be set from the Setup button.
Separate files – When enabled, render elements are generated into separate files. When disabled, render elements are stored into a single file. Note: exr file must be specified as an output file.
Setup – Opens the Render elements selection dialog.
UI Text Box
typeinfo
Render elements are not denoised regardless of Denoiser setting.
width5%
width35%
Output
width60%
Bake color corrections in EXR – When enabled, bakes color corrections and post effects in the EXR file. Note that this will clamp the dynamic range.
Save PNG alpha – When enabled, stores the environment in the alpha channel of the .png file. In the Save Image window, a .png file format must be specified.
Output path – Specifies the output file path where the still image is saved.
UI Text Box
typenote
In the Save Image window, a .png, .jpeg or .exr file type must be added after the specified file name.
e.g Camera01.png or Camera01.exr
width5%
width35%
Memory requirements
width60%
Pixel buffers – The amount of additional memory required for the currently set render resolution.
Denoiser – The amount of additional memory required for the denoiser.
Light Cache – The amount of additional memory required for the Light cache.
Approx. GPU memory needed – Displays an approximation of the additionally needed GPU memory to that shown on the right-hand side of the status bar for the currently set render resolution and settings. If the value is negative, less memory is required than that shown in the status bar.
width5%
width35%
width100%
Start – Starts rendering of the set Camera and current render settings. Button is disabled if there are cameras in the batch rendering queue.
Cancel – Closes the Render setup dialog.
Tabs Page
titleSequence
Camera
width60%
Auto-exposure – When enabled, exposure is automatically calculated for each frame. Set exposure in camera is ignored.
width5%
width35%
Resolution
width60%
<from editor> – Sets the render resolution to the forced resolution set in the Playback settings of the Animation editor.
<current resolution> – Sets the render resolution to the current core render resolution.
540p(960x540); HD 720p(1280x720); 900p(1600x900); FHD 1080p(1920x1080); 1440p(2560x1440); UHD 4K(3840x2160); UHD 8K(7680x4320); PC Video(640x480); NTSC(720x486); PAL(720x576); 1K Super 35(1024x778); 2K Super 35(2048x1556); 4K Super 35(4096x3112); 8K Super 35(8192x6224); 1K Cinemascope(914x778); 2K Cinemascope(1828x1556); 4K Cinemascope(3656x3112); 8K Cinemascope(3656x3112); 16K Cinemascope(7312x6224); 1K DCP(1024x540); 2K DCP(2048x1080); 4K DCP(4096x2160); 8K DCP(8192x4320); 512 Square(512x512); 1K Square(1024x1024); 2K Square(2048x2048); 4K Square(4096x4096);
Aspect - Sets the aspect of the render resolution.
width5%
width35%
Render
width60%
GI – Off;
GI bounces – 1;
Coat – On;
GI - On;
GI bounces – 2;
Coat – On;
Shading graph – On;
GI – On;
GI bounces – 3;
Coat – On;
Shading graph – On;
GI – On;
GI bounces – 4;
Coat – On;
Shading graph – On
Reduce flickering – Enables temporal rendering of the NVIDIA AI denoiser. Results and details may be blurry when enabled. Disabling it may increase image sharpness. Available only when Denoiser is set to NVIDIA AI.
Reduce flickering – Enables temporal rendering of the AI denoiser. Results and details may be blurry when enabled. Disabling it may increase image sharpness.
width5%
width35%
Render elements
width60%
UI Text Box
typeinfo
width5%
width35%
Output
width60%
Frame range
First frame – Specifies the first frame of the animation sequence.
Last frame – Specifies the last frame of the animation sequence.
Interval – Specifies the frame output at regular intervals. 1 renders every frame of the animation while for example 5 renders every 5th frame.
FPS – Specifies the frames per second for the animation.
Custom frames
Specify custom frame – Specifies custom frames and/or frame ranges to render. Example: 1, 5, 7-25, 50-100.
Output file type – Specifies the file type for the rendered sequence.
Image – Output of the animation is an imagesequence. In the Save Image window, a .png or .exr file format can be specified for the image sequence.
Image + MP4 – Output of the animation is an image sequence and an .mp4 file. In the Save Image window, a .png or .exr file format can be specified for the image sequence.
Image + MKV – Output of the animation is an image sequence and an .mkv file. In the Save Image window, a .png or .exr file format can be specified for the image sequence.
MP4 – Output of the animation is an .mp4 file.
MKV – Output of the animation is an .mkv file.
Video Quality – Specifies a preset for the .mp4/.mkv file quality. Not available when Output file type is Image.
Low; Medium; High;
UI Text Box
typenote
In the Save Image window, a .png or .exr file type must be added after the specified file name:
UI Text Box
typeinfo
width5%
width35%
Memory requirements
width60%
width5%
width35%
width100%
Render Queue
width60%
Adds a camera/animation sequence item, with current settings, to the render queue.
Clears the render queue.
A toggle that enables/disables the rendering of the camera/animation sequence in the render queue.
Name of render queue item.
Loads the camera/animation sequence settings to the Render setup dialog.
Overwrites the camera/animation sequence settings from the Render setup dialog.
Removes the camera/animation sequence from the render queue.
Thumbnail of the render camera.
Camera type.
Render resolution.
Selected scene state.
Frame range of animation sequence.
FPS of animation sequence.
width5%
width35%
