changes.mady.by.user Marcin Miodek
Saved on Jul 12, 2023
When enabled, a text displaying render information is added in the bottom right corner of the rendered output. You can click the little ∨ button before the checkbox to see the list of all available variables you can use.
UI Path ||Render Settings|| > Frame buffer settings tab > Frame Buffer.
The content of the render stamp accepts text and the special variables listed under the ∨ button.
