« Previous Version 7 Current »
This page provides information on the Raw Sheen Reflection Render Element.
The Sheen Render element is analogous to the Raw Reflection Render Element with the main difference being that all Sheen render elements can be subtracted from the main back-to-beauty composite, graded, and added back in.
UI Path: ||V-Ray|| > Render Elements > Raw Sheen Reflection
How to add a render element to a scene
Properties
Enable Deep OutputSpecifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
