This page provides information about the Reflection Filter Render Element in V-Ray for Cinema 4D.
While the Raw Reflection Render Element gives the full reflection of objects reflecting in the scene, Reflection Filter shows how much of that reflection should come through in the composite. In other words, the filter defines the strength of the reflection, while the raw image defines what is being reflected in the image. When these two elements are multiplied, the true level of reflection is given and produce Reflection. Using these component parts of the reflection, you can better fine tune the reflection in your final composite.
The Reflection Filter element is a sub-component in the main Beauty Pass.
UI Path: ||V-Ray|| > Render Elements > Reflection Filter
MultiExcerpt named AddBackground was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
How to add a render element to a scene
Properties
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
