This is a V-Ray application that is common across all V-Ray installations.
The VRImg to OpenEXR converter is both a command-line utility and a simple GUI application that can be used to convert .vrimg image files to .exr files in OpenEXR format. The .vrimg file format stores the rendered image with all available render elements. The V-Ray Image to EXR Converter converts .vrimg files to EXR format so the render elements may be loaded into compositing software, where they can be used for Back-to-Beauty compositing or for other adjustments and fine-tuning at the render element level.
Location
Currently, on all operational systems the vrimg2exr.exe is located in V-Ray's folder (where the V-Ray files are extracted) > appsdk > bin.
The page VRAYHOUDINI:VRAY4TOOLS:VRImg to OpenEXR Converter was not found -- Please check/update the page name used in the MultiExcerpt-Include macro
MultiExcerpt named converterGUIusage was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
MultiExcerpt named converterCmdUsage was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
MultiExcerpt named converterCmdNote was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
MultiExcerpt named converterOptions was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
