« Previous Version 57 Next »
This page provides information on managing render jobs in V-Ray Cloud.
With V-Ray Cloud you are able to submit, queue, monitor, and organize your render jobs across projects. Managing render jobs in V-Ray Cloud is done in one of two ways - using its web-based interface, or alternatively, via command-line interface.
Managing jobs with V-Ray Cloud's Interface
You can get into V-Ray Cloud's web interface by opening a web browser window and typing the following address: https://vray.cloud/. You will then be prompted to log in with your ChaosGroup account and password.
Once logged in, you will see V-Ray Cloud's main menu on the left. The button folds the menu bar in and out.
Projects
The Projects tab hosts all render jobs submitted to V-Ray Cloud. It allows organizing jobs in multiple projects, and is also where you can download the output of your render, resubmit a render, or delete a render from V-Ray Cloud.  Every render job needs to be allocated to a project.
To create a new empty project, press the button on the main menu on the left. A small pop-up window will appear asking you to enter a name for your project.
If Set as default is enabled, the newly created project will become the default one, meaning that all subsequent render job submissions will be automatically allocated to that project unless changed manually before submission.
To set a new default project, press the button while mouse-hovering over a project.
To delete a project, press the button.
To rename a project, press the button while hovering over a project's name.
Clicking on a project will show its contained render items. Here you can monitor, pause, cancel, delete, or download a render job.
To pause an ongoing render, click on the button while hovering over a render job.
To cancel an ongoing render altogether, click on the button.
To delete a completed render, press the button.
To download a completed render job, press the button.
Clicking on a render job within a project will open the Job Details page, displaying the finished render (if it's finished), information about it, as well as additional controls for downloading, resubmitting, or reporting a job.
To download the render job, press the button.
To delete the render job, press the button
To clone the render job, press the button.
To report the render job, if something went wrong, press the button.
To view the render log, press the button.
To rename the render job, press the button while hovering over its name.
Ongoing render jobs' progress can be observed in real-time from the Job Details page.
Cloning a render job using the button will allow you to set new final render settings.
Queue
The Queue tab is where all newly submitted, paused, or queued render jobs appear. From here you can monitor, pause, or cancel them.  No completed render jobs are listed here - they are all found at their respective project folder, allocated upon submission.
To pause an ongoing render job, click on the button while hovering over it.
You can have up to 3000 Submitted render jobs, and up to 10 Active render jobs.
Managing render jobs through command-line interface in V-Ray Cloud
 All functions offered by V-Ray Cloud's web-based interface can be carried out manually with any command-line tool, without opening a browser. To do so, you first have to navigate to the location of vcloud or vcloud.exe on your machine.
Default locations:
  • Windows – %appdata%\Chaos Group\V-Ray\V-Ray Cloud Client\vcloud.exe
  • macOS /Applications/ChaosGroup/V-Ray/V-Ray Cloud Client/vcloud
  • Linux$HOME/.ChaosGroup/vcloud/client/vcloud.bin
The table below list all available flags and commands. All commands can be run with multiple tags.
CommandFlag(s)Flag meaningFunctionExamples
auth login
Logs in to V-Ray Cloud.
vcloud auth login
auth logout Logs out of V-Ray Cloud.vcloud auth logout
eula
Prints out the EULA.
vcloud eula
job cancel--id (required)Render Job IDCancels a V-Ray Cloud job.vcloud job cancel --id=X8hC6Xg2cb8JeL5
job delete--id (required)Render Job IDDeletes a V-Ray Cloud job.vcloud job delete --id=X8hC6Xg2cb8JeL5
job download
--id (required)
--no-progress
--output (required)
Render Job ID
Do not display progress when downloading
Path to output folder
Downloads outputs of a V-Ray Cloud job.vcloud job download --id=X8hC6Xg2cb8JeL5 --output="C:\Users\Me\Desktop"
job pause--id (required)Render Job IDPauses a V-Ray Cloud job.vcloud job pause --id=X8hC6Xg2cb8JeL5
job rename
--id (required)
--title (required)
Render Job ID
The new title of the V-Ray Cloud job
Renames a V-Ray Cloud job.vcloud job rename --id=X8hC6Xg2cb8JeL5 --title="Marbles"
job submit
--sceneFile (required)
--animation
--colorCorrectionsFile
--frameRange
--frameStep
--height
--width
--ignoreWarnings
--name
--no-progress
--preserveAlpha
--project
--renderMode
--vr
Path to .vrscene file
Renders animation instead of a single shot
Path to color corrections file
Frame range of the animation
Frame step of the animation
Height of the rendered image
Width of the rendered image
Ignore warnings in scene file processing
Name of the rendering job
Do not display progress while submitting
Preserve alpha channel of PNG output
Name of the rendering project
Specifies the render mode
Renders VR-enabled image
Submits a V-Ray scene to V-Ray Cloud.vcloud job submit --sceneFile="C:\Users\Me\Desktop\soccer.vrscene --exr --project="Project Cloud" --renderMode=progressive --width=1280 --height=720
job resubmit
--id (required)
--animation
--frameRange
--frameStep
--height
--width
--ignoreWarnings
--name
--no-progress
--preserveAlpha
--project
--renderMode
--vr
Render Job ID
Resubmits a V-Ray scene to V-Ray Cloud.vcloud job resubmit --sceneFile="C:\Users\Me\Desktop\soccer.vrscene --png --project="Chaosology" --renderMode=bucket --animation --frameRange=30 --ignoreWarnings
job start--id (required)Render Job IDStarts a V-Ray Cloud job.vcloud job start --id=X40YITIaqtb_94E
job status--id (required)Render Job IDPrints status info for a V-Ray Cloud job.
project create
--name (required)
--default
Name of the project
Marks the project as default
Creates a new project.vcloud project create --name="Cloudy" --default
project delete--name (required)Name of the projectDeletes a project.vcloud project delete --name="Drains"
project listLists available projects.vcloud project list
project rename
--name (required)
--to (required)
Name of the project
The new name of the project
Renames a V-Ray Cloud project.vcloud project rename --name="Marbles" --to="Drains"
updateUpdates the V-Ray Cloud Client.vcloud update
versionPrints V-Ray Cloud Client version info.vcloud version
helpPrints command information.vcloud help; vcloud job help; vcloud job submit help
How to get a Job ID
A render job's ID can be obtained in two ways. Еither upon submission, through V-Ray Cloud's command-line interface:
Or from the URL of V-Ray Cloud's web interface when the Job Details page is open:
