« Previous Version 2 Next »
This page provides a tutorial on creating a lava simulation with Phoenix FD in 3ds Max.
Requires Phoenix FD 3.13 Release build or later and V-Ray Next Hotfix 1 Official Release for 3ds Max 2015+. If you notice a major difference between the results shown here and the behavior of your setup, please send an email to support@chaosgroup.com
The instructions on this page guide you through the process of using Phoenix FD's Variable Viscosity capabilities in order to simulate molten lava or metal cooling and hardening over a period of time.
The Download button below provides you with an archive containing the scene file.
Download Project Files
Units Setup
Scale is crucial for the behavior of any simulation. The real-world size of the Simulator in units is important for the simulation dynamics. Large-scale simulations appear to move more slowly, while mid-to-small scale simulations have lots of vigorous movement. When you create your Simulator, you must check the Grid rollout where the real-world extents of the Simulator are shown. If the size of the Simulator in the scene cannot be changed, you can cheat the solver into working as if the scale is larger or smaller by changing the Scene Scale option in the Grid roll-out.
The Phoenix FD solver is not affected by how you choose to view the Display Unit Scale - it is just a matter of convenience.
Go to Customize -> Units Setup and set Display Unit Scale to Metric Centimeters.
Also, set the System Units such that 1 Unit equals 1 Centimeter.
Scene Layout
The final scene consists of the following elements:
  1. A Standard Primitives → Box used as the source geometry for the liquid. An animated Noise modifier is applied to the geometry to break up the emission.
  2. A set of rocks provided with the rocks.abc file.
  3. Phoenix FD Liquid Source with the Box in its Emitter Nodes list. The Source is in Surface Force mode and Noise is enabled for extra randomization.
  4. Phoenix FD Liquid Simulator with some tweaks in the Grid, Dynamics, and Rendering roll-outs.
  5. Phoenix FD Mapper used to tweak the Viscosity of the liquid during the simulation.
  6. V-Ray Physical camera with minor tweaks for final rendering.
  7. A V-Ray Dome Light using a custom HDRI.
  8. V-Ray Plane used as an infinite ground surface.
Scene Setup
Set the Time Configuration → Animation Length to 150 so that the Time Slider goes from 0 to 150.
Import the rocks.abc geometry by going to File → Import → Import...
We start off with pre-built geometry to save time setting up the scene. Feel free to use your own personal models.
The size of the bounding box of the three rocks used in this example is:
[ X: 155cm, Y: 60cm, Z: 75cm ].
Let's add the geometry used to emit the lava.
Create a Geometry → Standard Primitives → Box.
Use the to Move tool to place the box above the rocks. The exact transformation values are X/Y/Z: [ 73/3/137 ].
Set the Length/Width/Height to 38/33/5 , and the Subdivisions along the Length/Width/Height to 5/5/1.
The subdivisions are needed later in this tutorial when a Noise modifier is added to the Box to randomize the emission pattern.
Add a Helpers → Phoenix FD → Liquid Source. The Liquid Source is a Phoenix FD helper node used to tell the Simulator which objects in the scene will emit, how strong the emission will be, etc.
Add the Box geometry to the Emitter Nodes list. For the time being leave all other options at their default values.
Create a Geometry → Phoenix FD → Liquid Simulator.
Set the Grid → Cell Size to 1.0cm. The lower the Cell Size is, the more detailed the simulation will be but the longer it will take to complete. We start off with a reasonably small value so we can iterate quickly over different parameter variations.
The Size of the Simulator is set to [X: 80, Y: 80, Z:150 ].
Set the Grid → Container Walls → Z: Jammed ( - ). When a Container Wall is Jammed, it acts as a solid wall against which the liquid will collide.
The exact Position of the Simulator in the scene is [ X:75cm, Y:2cm, Z:0cm ].
To the right is a Viewport Preview showing the result of the simulation so far.
At the moment, liquid is being emitted from the entire Box geometry.
Instead, we would like to emit only from the bottom faces of the Box.
We take a look at one possible solution in the next step.
The Phoenix FD Source nodes can use the Polygon IDs of an object to limit the emission only to those faces which share a certain ID.
Assign an Edit Poly modifier to the Box geometry and go into Face Selection mode.
Select all faces and give them an ID of 1.
Then, select only the bottom faces which will be used for emission of liquid and assign them an ID of 2.
The cameras on the screenshot to the right have been added to the scene to generate the Viewport Previews. The final camera setup will be discussed in the Rendering section of this tutorial.
Set the Polygon ID parameter of the Phoenix FD Liquid Source to 2 so that only the faces with this ID are used for emission.
The liquid is now correctly being emitted only from the bottom faces of the Box geometry.
Reduce the Phoenix FD Simulator → Dynamics → Time Scale to 0.6.
Reducing the Time Scale will slow down the liquid thus giving it a more dramatic appearance.
Reducing the Time Scale has slowed down the liquid but there are stepping artifacts that need to be resolved. Stepping is usually caused by the liquid having to travel a large distance over a single frame. The most straight-forward way to eliminate the stepping is to increase the Dynamics → Steps Per Frame parameter - this allows Phoenix FD to re-calculate the motion of the liquid multiple times per frame (depending on the Steps Per Frame value).
Instead of increasing the Steps Per Frame, in this tutorial we rely on the randomness provided by tweaks to the emission and the Viscosity and Surface Tension to hide the stepping artifacts and thus saving on simulation time.
Select the Phoenix FD Liquid Source and set Viscosity to 0.2.
Viscosity emulates thickness - the higher this value is, the more the liquid will resemble thick mud, honey or in this case - lava.
Under the Output roll-out of the Phoenix FD Simulator, enable the export of the Viscosity Grid Channel.
Also enable the export of the Viscosity Liquid Particle Channel.
Outputting those channels is required for the calculation of Viscosity for the liquid to work.
The liquid feels much thicker now, and the stepping artifacts are much less pronounced.
In the next step we animate to Box geometry to move to the right so the lava pours all over the stones.
Animate the Box geometry with the following keyframes:
Frame 0: [ X: 73 | Y: 3 | Z: 137 ]
Frame 67: [ X: -24.5 | Y: 3 | Z: 137 ]
Frame 132: [ X: 53 | Y: 3 | Z: 137 ]
Frame 150: [ X: 45 | Y: -4 | Z: 137 ]
Enable Phoenix FD Simulator → Grid → Adaptive Grid and Maximum Expansion. The red box in the screenshot to the right is a preview of the Maximum Bounds for the simulation. Adaptive Grid is a huge time saver - the initial grid is dynamically expanded to accommodate the movement of the liquid, cutting down on both processing time and memory. If you notice any clipping, increase the Extra Margin to a value of 5 - 10. This will add a few extra voxels at the borders during adaptation.
The Adaptive Grid Maximum Expansion settings are X: [ 200, 100 ], Y: [ 100,100 ] and Z: [ 0, 0 ].
Now that the liquid is pouring all over the stones we can see that it's not sticking to them at all.
In the next step we enable Wetting so the lava can stick to the rocks.
Enable Phoenix FD Simulator → Dynamics → Wetting. When Wetting is enabled, Phoenix FD generates another set of particles called WetMap particles. Those particles are created at the point of contact between the liquid and the scene geometry and can be used to drive shaders (through a Phoenix FD Particle Texture) or specify where the liquid should try to adhere to. You can disable Wetting for a specific object in your scene from its Phoenix FD Per-Node Properties.
Set Sticky Liquid to 0.1. The lava will now try to adhere to the stones.
The lava is now naturally flowing over the stones.
At the moment the entire bottom side of the box geometry is emitting lava giving the fluid an unnatural cubic appearance.
In the next few steps we randomize the emission for a more natural looking lava.
Select the Phoenix FD Liquid Source and set the Noise parameter to 0.2. This option works as a multiplier on the Outgoing Velocity - some areas of the emission geometry will emit with a higher Outgoing Velocity while other areas will be weaker.
Click on the "No Map" button to the left of Mask and plug a Noise texture.
Finally, increase the Outgoing Velocity to 300 - this value is completely arbitrary and can be modified based on the requirements of your setup.
Here are the exact values for the Noise texture:
Source: Explicit Map Channel
Type: Fractal
Threshold High: 0.6
Threshold Low: 0.55
Levels: 8
Phase: 14
Color 1: RGB [ 64, 64, 64 ]
Color 2: RGB [ 255, 255, 255 ]
Feel free to tweak the settings based on your own artistic judgement.
Reduce the Phoenix FD Simulator → Grid → Cell Size to 0.64 so the extra detail provided by the Noise texture can come through.
The emission pattern is now much more natural.
Furthermore, the higher Outgoing Velocity is causing the lava to splash as it hits the rocks.
For even more randomness, add a Noise modifier to the Box emission geometry:
Here are the exact values used in this setup:
Scale: 51
Fractal : Enabled
Strength X/Y/Z: 5
Animate Noise: Enabled
Increase the Phoenix FD Simulator → Dynamics → Surface Tension to 0.05. Surface Tension helps keep the liquid together.
At the moment the Viscosity of the lava is completely uniform. Real lava has different viscosity depending on its temperature. Hot lava resembles liquid and stiffens as it cools down.
In the next step we randomize the Viscosity with a Noise texture.
Click the No Map under Phoenix FD Liquid Source → Viscosity→ Map. Add a Noise texture from the pop-up menu.
Increase the Viscosity parameter to 1.0. Usually a value of 1.0 is way too high but since the Noise texture has high-frequency detail, with most of the values in the texture much below 1.0, the final result will be significantly lower after the Viscosity is multiplied by the provided texture map.
Noise Type: Regular
Threshold High: 1.0
Threshold Low: 0.45
Color 1: RGB [ 56, 56, 56 ]
Color 2: RGB [ 175, 175, 175 ]
The difference after modifying the Viscosity with a texture is not immediately obvious but once the Cell Size is reduced for the final simulation, individual chunks of lava will start forming based on the different viscosity values.
Solidifying with a Phoenix FD Mapper
In this section of the tutorial, we look into the process of using the Phoenix FD Mapper to gradually increase the viscosity of the lava over time. Real-world lava solidifies as it cools down - we want to replicate this behavior.
Create a Helpers → Phoenix FD → Mapper. The Phoenix FD Mapper can directly affect the components of the simulation. For instance, it can be used to overwrite the Viscosity values for certain cells of the Simulator.
Disable the Initializer option - if enabled, the Mapper will only work on the first frame of the simulation. When disabled, the Mapper is always active.
Set the Channel to affect to Visocsity.
Set Buildup Time to 0 so the Mapper will instantly set the cells of the Phoenix FD Simulator to the values of the Map texture for each frame of the simulation.
Finally, plug an Output texture to the Map slot of the Mapper. When you start a simulation, the Mapper will look at this texture to determine what values to apply to the cells of the Simulator.
Set the Output texture's Output Amount parameter to 1.0.
With the Mapper's Buildup Time set to 0 (i.e. instant Buildup) and the Output Amount set to 1, the expected behavior is for the Viscosity channel to be overwritten by the Mapper such that it's always at 1.
As expected, the lava now has a constant Viscosity of 1. The setup is working as intended.
Set the Output Texture's Amount to 0.8 - this is the maximum viscosity value for the lava to eventually reach.
Set the Mapper's Buildup Time to 4 - with this setup, it will take 4 seconds for the lava to reach a Viscosity value of 0.8.
The lava now solidifies as over time - the effect is noticeable around the time when the liquid interacts with the stones geometry. There are fewer splashes and overall the shape is no longer being torn apart.
In the next step we add a Gradient Ramp as a Mask to the Mapper so it only affects the very bottom of the simulator. We want the lava to remain hot (and with low viscosity) until it settles on the ground. At this point the Mapper will start affecting it, increasing its viscosity thus causing it to solidify.
Add a Gradient Ramp texture to the Mapper's Mask parameter.
Here are the exact settings for the Gradient Ramp texture:
Mapping: Planar from Object XYZ
Projection: ZX
Ramp Position 0: RGB [ 255, 255, 255 ]
Ramp Position 44: RGB [ 0, 0, 0 ]
Ramp Position 100: RGB [ 0, 0, 0 ]
The Gradient Ramp is being projected (Mapping: Planar) from top to bottom such that the White areas are applied to the lower half of the simulator and the Black areas - to the upper half. The Mapper will only affect the areas of the Simulator where the Mask texture (the Gradient Ramp) is White, i.e the lower half.
For in-depth information regarding the Mapper and how to use it, please take a look at the Simulation RGB Workflows tutorial or the Phoenix FD Mapper's Documentation.
The lava now splashes as it hits the stones but calms down and solidifies as it settles on the ground.
Note the small droplets of lava flying away from the stones geometry - in the next couple of steps we try to remedy this problem by increasing the Steps Per Frame and reducing the Cell Size of the simulation.
There are many stray particles flying all over the place as the lava collides with the stones. Not only is this effect unnatural but it also drastically increases the simulation time by expanding the Adaptive Grid to its maximum extents.
Increase the Phoenix FD Simulator → Dynamics → Steps Per Frame to 2 to remedy this. Increasing the Steps Per Frame will usually produce calmer fluids - this is true both for Liquid and Fire/Smoke simulations.
Increasing the Steps Per Frame substantially reduced the detail in the simulation but also helped resolved the problem with individual droplets flying all over the place.
We can further reduce the Cell Size to gain back some of that detail.
Reduce the Phoenix FD Simulator → Grid→ Cell Size to 0.35.
This is the final shape of the Lava simulation.
Increasing the Steps Per Frame was required to eliminate the stray droplets.
Reducing the Cell Size gave us more detail in the fluid.
In the next step we set up the RGB channel for the Lava shader.
Click the No Map under Phoenix FD Liquid Source → RGB→ Map. Add a Noise texture from the pop-up menu.
Here are the exact settings for the Noise texture:
Type: Fractal
Threshold High: 1
Threshold Low: 0.45
Levels: 3
Phase: 0
Color 1: RGB [ 180, 17, 0 ]
Color 2: RGB [ 254, 102, 1 ]
Feel free to tweak those based on your own artistic judgement.
Set Phoenix FD Simulator → Dynamics roll-out → RGB Diffusion to 0.1.
The RGB Diffusion parameter controls how quickly the colors of particles are mixed over time during the simulation. When set to 0, each liquid particle carries its own color, and the color of each individual particle does not change when liquids are mixed. This means that if red and green liquids are mixed, a dotted red-green liquid will be produced instead of a yellow liquid. This parameter allows the colors of particles to change when the particles are in contact, thus achieving uniform color in the resulting mixed liquid. For more information, see the RGB Diffusion example.
Enable Output → Grid Channels → RGB. This is required for the simulation of the RGB channel to work.
Make sure to also enable Output → Grid Channels → Velocity. The Velocity Grid Channel is used when rendering with Motion Blur.
Go to Simulation → Start to run the final simulation.
To the right is a low-quality render of the liquid mesh with a Phoenix FD Grid Texture reading the RGB Grid Channel applied to a V-Ray Material's Diffuse slot.
Camera & Light
Add a Command Panel → Cameras → V-Ray → VRayPhysicalCamera.
The exact position of the Camera is XYZ: [ 2, 318, 108 ].
The exact position of the Camera Target is XYZ: [ 16, 11, 44 ].
The Aperture → F-Number is set to 0.8.
The Aperture → Shutter Speed is set to 1000.
Both Depth of Field and Motion Blur are Enabled.
Color & Exposure → White Balance is set to D50.
Bokeh Effects → Blades is Enabled, with a value of 7. Rotation is set to 15, with a Center Bias of 1.
 The V-Ray Settings → Rendering Output Width / Height is set to 800 / 450 for the example renders below.
Add a Command Panel → Lights → V-Ray → V-Ray Light.
Set the Light Type to Dome.
Set the Multiplier to 1.
Enable Options → Invisible so the Dome Light is not visible in the rendered image but still provides illumination in the scene.
Plug a V-Ray HDRI as the Dome Texture and set the Overall Mult. and Render Mult. settings to 2 to brighten up the image.
In this example, we use an HDRI map called "Paul Lobe Haus" from the HDRI Heaven webisite.
 Click here for the link to the HDRI page.
Set the Rendering → Environment → Background Color to RGB: [ 15, 16, 21 ].
Add a V-Ray Infinite Plane by going to Geometry → Standard Primitives → VRayPlane.
To the right is a rendered image of the current setup plus the basic materials we create in the next section.
Materials for the Rocks and Ground
Assign a V-Ray Material to the V-Ray Plane and rename it to mtl_ground.
Set the Diffuse to [ 2, 2, 2 ]
Set Reflect to [ 21, 21, 21 ]
Set Reflection Glossiness to 0.65.
Add a new Noise texture and plug it into the Bump map slot of mtl_ground.
Tiling: 10
Noise Type: Fractal
Threshold High: 0.775
Threshold Low: 0.5
Levels: 10
Here's a rendered image of the V-Ray ground plane with mtl_ground applied.
For the rocks, assign a V-Ray Material and rename it to mtl_rocks.
Add a new Noise texture and plug it into the Bump map slot of mtl_rocks.
Tiling: 1
Noise Type: Fractal
Threshold Low: 0.5
Levels: 10
Here's a rendered image of the Rocks geometry with mtl_rocks applied.
Material for the Solid Lava
For the solid lava (the one with high Viscosity), assign a V-Ray Material to the Phoenix FD Simulator and rename it to solidLava. This material is the base for the final Complex Lava material we create in the next section.
Set the Diffuse to [ 1, 2, 3 ].
Set Reflect to [ 55, 55, 55 ].
Set Reflection Glossiness to 0.72.
Reduce the Bump to 15 under the Maps roll-out of the V-Ray material.
Add a new Noise texture and plug it into the Bump map slot of the solidLava material.
The Source is set to Explicit Map Channel.
The Noise Type is set to Regular.
Threshold High is set to 0.775.
Threshold Low is set to 0.5.
The Noise Size is set to 0.5.
Here's a rendered image of the Lava with the solidLava material applied to the Simulator.
Material for the Liquid Lava
The material for the liquid lava consists of a regular V-Ray Material (coldLiquidLava) and a V-Ray Light Material (hotLiquidLava) blended together based on the output of a Phoenix FD Grid Texture reading the simulation's RGB Channel.
The hotLiquidLava Light Material is the core of the lava shader - the emitted light's color is based on the RGB Channel read through a Grid Texture.
The coldLiquidLava V-Ray Material is added into the mix for additional variation. Even very hot lava flows in real life has chunks of rocks that do not emit light. Having only a single Light Material would look unrealistic.
The Blend input of the liquidLava Blend Material is driven by the same RGB Channel - a Color Correct and Output nodes are used in-between to de-saturate and increase the contrast of the RGB Channel values.
To start off, create a V-Ray Blend Material and assign it to the Phoenix FD Simulator. Rename it to liquidLava.
Create a V-Ray Material and plug it into the Base input of the liquidLava Blend Material. Rename it to coldLiquidLava.
Set the Diffuse Color to RGB: [ 1, 2, 3 ].
Create a V-Ray Light Material and plug it into the Coat 1 input of the liquidLava Blend Material. Rename it to hotLiquidLava.
Set the Color to RGB: [ 0, 0, 0 ] - we use a Phoenix FD Grid Texture reading the simulation RGB Channel to drive the color of the emitted light.
Set the Color Multiplier to 100 - this will affect the intensity of the emitted light.
Create a Phoenix FD Grid Texture and plug it into the hotLiquidLava Light Material's Light Color input. Rename it to gridRGB.
Click the Pick a Phoenix Simulator button next to the Source Node parameter and select your Phoenix FD Simulator from the pop-up menu. The name of the button should change according to the name of the simulator once you hit the OK button.
Set the Channel to Grid RGB - this is the channel the texture will read from the cache files.
Set the Sampler to Spherical. You can think of the sampling process as Anti-Aliasing - the Box sampler will give you a rough texture, the Linear will try to smooth the colors and the Spherical will produce the smoothest result. Note that Spherical is 20-30% slower than Linear so make sure to check if the additional sampling at the expense of render time is worth with your setup.
Create a Color Correction node and plug the gridRGB texture into the Map slot. Rename the Color Correction node to desaturateRGB.
Set the Color → Saturation to -100.
Set the Lightness → Contrast to 100.
Create an Output node and plug the Color Correction texture into the Map slot. Rename the Output node to incOutputRGB.
Set Output → Output Amount to 2.0. Doing so will essentially boost the contrast in the RGB values even further.
To the right is a rendered image of the incOutputRGB Output texture applied to the Diffuse Color of a default V-Ray Material.
Plug the incOutputRGB Output texture into the Blend 1 slot of the liquidLava Blend Material.
To the right is a rendered image of the current setup.
Complete Lava Shader
The final material for the lava consists of the coldSolidLava and liquidLava materials we prepared in the previous two sections of this tutorial.
A V-Ray Blend Material is used at the final wrapper. The Blend Material is driven by a Phoenix FD Grid Texture reading the Viscosity Grid Channel. Recall that the Viscosity in the simulation increases as the simulation progresses in time. Thus, higher viscosity values should correspond to solid lava with the coldSolidLava material applied.
The purpose of the Output node is to invert the values coming in from the Grid Texture. Note that the Coat 1 input of the Blend material is the liquidLava material. The Coat 1 is applied where the Blend texture is white. Therefore, if the Grid Texture output is not inverted, the high-viscosity areas of the simulation will receive the liquidLava material which would be incorrect.
Create a V-Ray Blend Material and rename it to Lava.
Plug the coldSolidLava material in the Base input.
Plug the liquidLava material in the Coat 1 input.
Create a Phoenix FD Grid Texture and rename it to gridViscosity.
Set the Channel to Grid Viscosity - this is the channel the texture will read from the cache files.
Create an Output texture and plug the gridVisocisty Grid Texture.
Set the Output Amount to 3. Doing so will essentially boost the contrast in the Viscosity values.
Enable Invert. If the Grid Texture output is not inverted, the high-viscosity areas of the simulation will receive the liquidLava material instead of the coldSolidLava material.
Finally, plug the Output texture into the Blend 1 slot of the Lava Blend Material.
To the right is a rendered image of the final Lava material.
Mesh Smoothing for the Lava Mesh
Optionally, you may choose to enable some Simulator → Rendering → Mesh Smoothing options if your lava simulation looks too sharp / jagged.
The settings for the smoothed image to the right are Simulator → Rendering → Use Liquid Particles enabled, and a Smoothness of 5.
Lava No Smoothing
Lava With Smoothing
V-Ray Frame Buffer
For the final image, some corrections are made in the V-Ray Frame Buffer.
Bloom/Glare Effect is enabled from the Lens Effects panel. The Size is set to 22, with a Bloom of 0.11.
Exposure is enabled from the Corrections panel and reduced to -1 to counter the brightening effect of the Bloom effect.
White Balance is also enabled and Temperature set to 8000 to pull the image away from the blue overall tint created by the Bloom effect.
