« Previous Version 3 Next »
This page provides information on the Phoenix FD Test operator for Particle Flow.
This Particle Flow operator checks the fluid in the particle's position. If the value of the selected channel is above/below a given threshold, it redirects the particle into a different event.
||Particle View window|| > Depot > PhoenixFD Test
||Particle View window|| > Event Display right click menu > New > Test Event > PhoenixFD Test
Phoenix node | node – Determines which simulator will be used.
Source channel | srcchannel – Determines which channel will be used.
Level | level – Specifies the threshold level.
Variations | var – Specifies variations in the level in absolute values.
True if below | invert – Inverts the behavior of the test.
