« Previous Version 4 Next »
This page provides information on how MaxScript can be used with Phoenix FD.
During the simulation process you can directly access the simulator's content using functions exported by the plugin.
You can use these to script advanced simulation rules, or to e.g. control a simulation on a remote machine that runs using only a Simulation License.
These functions can only be called when the simulator is in the appropriate internal state. The moments of time when the content can be manipulated properly are signaled by calling several callback functions, and you can access the simulator's content only inside them. Every single Phoenix FD object has its own script code that is kept in the scene file. When the simulation starts, the script is compiled, and its callback function overrides the callback functions of any previous simulation. During the simulation, you can change the script by executing the Evaluate all command from the File menu of the script editor. If a shared script for all simulator instances is desired, you have to delete the individual scripts for each simulator and deliver the callback functions as an ordinary MAXScript file.
Callback functions
These functions are available when you enable Use Script in the Simulation rollout of a Phoenix Simulator.
At different moments of the simulation, Phoenix will call them and you can add your custom MAXScript code inside.
For example, it is possible to script starting another Simulator automatically once a simulation ends, or start of a sequence or single frame rendering.
The following function are available:
FunctionDescription
OnSimulationBeginCalled after the initialization of the simulator is done and before first execution.
OnSimulationStepCalled before each simulation step, after the interaction with the scene.
OnSimulationEndCalled after the end of the simulation. The simulation core would be already destroyed during this callback so it should not be accessed.
OnNewFrameCalled after each frame export.
Global functions
Each of the simulation channels (temperature, velocity, smoke etc.) exists in two instances - in the simulation core and in the simulation result. The functions in this section can access both the simulation core and result. If the first argument passed to the function specifies a Phoenix FD node, then the function accesses the simulation result. If there is no explicit Phoenix FD node specified, the function accesses the simulation core. In this case the target node is delivered internally. All the functions are exported as global functions beginning with "A_".
It should be noted that the simulation core exists only during the simulation and can be accessed only in the Callback functions.
FunctionsDescription
A_SetSystem
Parameters:
system:<integer>
Available options are:
0 - Object space
1 - World space
2 - Grid (voxel) space
Return value:
 none
Specifies which coordinate system will be used.
A_Inject
Parameters:
where:<point3>
amount:<float>
[temperature:<float>]
[smoke:<float>]
[velocity:<point3>]
[RGB:<point3>]
Return value :
none
Injects fluid in a given point. Using this function, you can create your own procedural sources. The result of the function CAN NOT be achieved by calling one or more A_SetX functions, because they do not affect the quantity of the fluid, but only the parameters carried by the fluid. The injection of fluid in some point causes changes in the content only of the nearest 8 cells, but produces an outgoing flow in the entire grid. Nevertheless the function is not slower than the ordinary A_SetX function, because the outgoing flow appears later, when the simulation is executed. If A_GetV function is executed immediately after A_Inject in some near point, the velocity will not be changed.
A_SetV
Parameters:
x:<integer>
y:<integer>
z:<integer>
velocity:<point3>
Return value :
none
Sets the velocity of a cell. If a Simulator name is used, the function will write to the loaded cache, otherwise the function will write into the grid of the running simulator, if any.
A_SetRGB
Parameters:
x:<integer>
y:<integer>
z:<integer>
RGB:<point3>
Return value :
none
Sets the RGB of a cell. If a Simulator name is used, the function will write to the loaded cache, otherwise the function will write into the grid of the running simulator, if any.
A_SetT
Parameters:
x:<integer>
y:<integer>
z:<integer>
temperature:<float>
Return value :
none
Sets the Temperature of a cell. If a Simulator name is used, the function will write to the loaded cache, otherwise the function will write into the grid of the running simulator, if any.
A_SetSm
Parameters:
x:<integer>
y:<integer>
z:<integer>
smoke:<float>
Return value :
none
Sets the Smoke of a cell. If a Simulator name is used, the function will write to the loaded cache, otherwise the function will write into the grid of the running simulator, if any.
A_SetFl
Parameters:
x:<integer>
y:<integer>
z:<integer>
fuel:<float>
Return value :
none
Sets the Fuel of a cell. If a Simulator name is used, the function will write to the loaded cache, otherwise the function will write into the grid of the running simulator, if any.
A_GetFl
where:<Point3>
Return Value:
<float>
Gets the Fuel in a given point. If a Simulator name is used, the function will read from the loaded cache, otherwise the function will read from the running simulator, if any.
A_GetV
where:<Point3>
Return Value:
<point3>
Gets the Velocity in a given point. If a Simulator name is used, the function will read from the loaded cache, otherwise the function will read from the running simulator, if any.
A_GetRGB
where:<Point3>
Return Value:
<point3>
Gets the RGB in a given point. If a Simulator name is used, the function will read from the loaded cache, otherwise the function will read from the running simulator, if any.
A_GetT
where:<Point3>
Return Value:
<float>
Gets the Temperature in a given point. If a Simulator name is used, the function will read from the loaded cache, otherwise the function will read from the running simulator, if any.
A_GetSm
[node:<Simulator>]
where:<Point3>
Return Value:
<float>
Gets the Smoke value in a given point. If a Simulator name is used, the function will read from the loaded cache, otherwise the function will read from the running simulator, if any.
A_StartSim
node:<Simulator>
[cache: <String>]
[startframe: <integer>]
Starts the simulation. Passing just the simulator node will start a new simulation. If you pass the path to a cache file, the effect is that of the Load button in the Simulation rollout: the simulation state will be loaded from the cache and the simulation will continue from the specified Start Frame. If you manually pass the startframe index too, it takes precedence over the Load function and the simulation will be restored from the given frame, the same way that the Restore button works.
This function will decide between simulation and re-simulation depending on the state of the Particle Resimulation and Grid Resimulation switches.
A_StopSim
node:<Simulator>
Stops the simulation
A_Wait
node:<Simulator>
This function halts the execution of the script until the specified simulator has finished running. Usually this function is used along A_StartSim when you want to run certain actions after the simulation is finished.
Use this function extremely carefully because it does not block the GUI of 3ds Max.
A_CreateParticle
Particle group:<string>
where:<Point3>
[Radius:<float>]
[Velocity:<Point3>]
Return Value:
none
Creates particle in given position with given properties.
A_Freeze
Parameters:
x:<integer>
y:<integer>
z:<integer>
Freezes the given cell. The frozen cell act as a solid object
A_Unfreeze
Parameters:
x:<integer>
y:<integer>
z:<integer>
Unfreezes the given cell. Keep in mind that the simulator counts the freezing and you have to execute the same count of unfreezing operation to successfully unfreeze a cell
A_QuickSetup
Parameters:
setup: <integer>
0 - fire
1 - fuel fire
2 - explosion
3 - gasoline explosion
4 - large smoke
5 - cold smoke
6 - cigarette smoke
7 - candle
8 - clouds
9 - tap water
10 - milk
11 - beer
12 - coffee
13 - honey
14 - liquid chocolate
15 - blood
16 - paints
17 - ink in water
18 - waterfall
19 - ocean
Return Value:
none
Creates a Quick Simulation with the selected object.
A_LoadRenderPreset
node: <Simulator>
preset path: <String>
Loads the specified render preset file. The preset path can be a full path or use the $(dir) macro, which denotes the current scene file's directory.
For example, the following will load "preset.tpr" from the current scene directory:
A_LoadRenderPreset (getnodebyname "PhoenixFDFire001") "$(dir)\preset.tpr"
A_SaveRenderPreset
node: <Simulator>
Saves a Phoenix FD render preset to a file with the current render and preview settings. The preset path can be a full path or use the $(dir) macro, which denotes the current scene file's directory.
A_LoadSimPreset
node: <Simulator>
Loads the specified simulation preset file. The preset path can be a full path or use the $(dir) macro, which denotes the current scene file's directory.
A_LoadSimPreset (getnodebyname "PhoenixFDFire001") "$(dir)\preset.tpr"
 A_SaveSimPreset
node: <Simulator>
Saves a Phoenix FD simulation preset to a file. The preset path can be a full path or use the $(dir) macro, which denotes the current scene file's directory.
Per-node functions
Phoenix FD provides an interface for getting grid data and loading render presets directly from the Simulator node.
The available functions are:
setCoordSys – Specifies which coordinate system will be used.
0 - Object space
1 - World space
loadRenderPreset – Loads a previously saved Phoenix FD render preset from a file.
saveRenderPreset – Saves a Phoenix FD render preset to a file with the current render and preview settings.
loadSimPreset – Loads a previously saved Phoenix FD simulation preset from a file.
saveSimPreset – Saves a Phoenix FD simulation preset to a file with the current render and preview settings.
getVelocity – Gets the Velocity value in a given point.
getRGB – Gets the RGB value in a given point.
getTemperature – Gets the Temperature value in a given point.
getSmoke – Gets the Smoke value in a given point.
getFuel – Gets the Fuel value in a given point.
Example usage:
$PhoenixFDFire001.getFuel (Point3 15 15 15)
Global Variables
The following global variables are initialized before entry in the callback functions:
VariableDescription
this:<simulator>Points to the simulator that calls the callback function
t:<float>The simulator's internal time
dt:<float>The simulator's internal step
