« Previous Version 2 Next »
This page provides information about the Cryptomatte render element in V-Ray for SketchUp.
Cryptomatte is a method developed by Psyop for efficiently encoding accurate mattes. It typically uses three to five automatically generated render channels stored in a multichannel OpenEXR file which removes the hassle of creating dozens or hundreds of Multimattes.
Compared to the Multimatte Render Elements, Cryptomatte offers the following:
  • Does not require a setup with object IDs, etc.
  • Only requires a fixed number of additional render elements, typically four.
  • Cannot be propagated through reflections or refractions.
Currently, Cryptomatte render element works only with the Bucket Image Sampler (Progressive switched off).
UI Path
||V-Ray Asset Editor|| > Create Asset > Render Elements > Cryptomatte
ID Type – Specifies how the ID mattes are created.
Object Name – Creates mattes based on object names. Note that object IDs are used in case no scene name is specified.
Material Name – Creates mattes based on the materials in the scene.
Object Name with Hierarchy – Creates mattes by object names with full scene hierarchy path.
Layer Names – Creates mattes based on the layer names the object belongs to.
