« Previous Version 4 Next »
This page provides information on the Raw Coat Reflection Render Element.
The Raw Coat Reflection Render element is analogous to the Raw Reflection Render Element with the main difference being that all Coat render elements can be subtracted from the main back-to-beauty composite, graded, and added back in.
The Raw Coat Reflection Render Element stores reflection information calculated from the materials' reflection values in the scene. Surfaces with no reflection values set in their materials will contain no information in the render element, which means these areas will render as black. When the Raw Coat Reflection Render Element is multiplied by the Coat Filter, the Coat Render Element is produced.
The Raw Coat RE gives the full reflection of objects reflecting in the scene, while the reflection filter Coat Filter sets how much of that reflection should come through in the composite. In other words, the filter defines the strength of the reflection, while the raw image defines what is being reflected in the image. When these two elements are multiplied, the true level of reflection is given as the Coat RE. By using these component parts of the reflection, you can fine-tune the reflection in your final composite.
UI Path: ||V-Ray|| > Render Elements > Raw Coat Reflection
Properties
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Aa – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
