This page provides tables of features supported in CPU and GPU rendering with V-Ray in Rhino.
These features are supported by V-Ray in Rhino for Interactive and Non-Interactive rendering modes.
Both RTX and CUDA share the same V-Ray GPU engine supported features.
For more information on V-Ray GPU, see the GPU Rendering.
Supported Features
Main Render features
Feature | V-Ray CPU | V-Ray GPU |
Interactive rendering | ||
Progressive image sampler | ||
Bucket image sampler | ||
Resumable rendering | ||
V-Ray Denoiser | ||
NVIDIA AI Denoiser1 | ||
Intel Open Image Denoise | (always calculated by CPU) | |
Viewport rendering (VPR) | ||
Viewport region rendering | ||
Batch rendering | ||
Cloud rendering | ||
Batch render in Cloud | ||
Distributed rendering via Swarm | ||
Rendering in Grasshopper | ||
Unbacked Grasshopper geometry |
Environment Background Mapping
Spherical mapping | ||
Mirror ball mapping | ||
Angular mapping | ||
Cubic mapping | ||
Screen mapping | ||
Color/Texture Multipliers |
Global Illumination Methods
Brute Force | ||
Light Cache | ||
Irradiance Map | ||
GI Caustics |
Camera
VRayPhysicalCamera | ||
Camera Depth of Field | ||
Camera motion blur | ||
Stereoscopic | ||
VR Cubemap | ||
VR Spherical Panorama | ||
Automatic Exposure | ||
Automatic White Balance | ||
Film sensitivity (ISO) | ||
Aperture (F-Number) | ||
Shutter Speed (1/s) | ||
Vignetting | ||
Vertical Tilt | ||
Bokeh |
Geometry
Triangle meshes | ||
VRayProxy | ||
Alembic via proxy | ||
Subdivisions | ||
Displacement | ||
VRayFur | ||
Infinite plane | ||
VRayClipper | PARTIAL (Only Section Plane) | |
V-Ray Scene | ||
V-Ray Scatter | ||
V-Ray Decal |
Lights
SunLight | PARTIAL (Affect Diffuse and Specular controls not supported) | |
Rectangle Light | PARTIAL (Decay control not supported) | |
Sphere Light | PARTIAL (Decay control not supported) | |
Spot Light | PARTIAL (Affect Diffuse and Specular controls and Inverse cube decay not supported) | |
IES Light | ||
Omni Light | PARTIAL | |
Mesh Light | PARTIAL | |
Dome Light | ||
Directional Light | PARTIAL (Affect Diffuse and Specular controls not supported) |
Materials
Blend | ||
Car Paint | ||
Emissive | PARTIAL | |
Generic (V-Ray Material) |
Override | PARTIAL (without Environment) | |
Two Sided | PARTIAL (without Multiply By Front diffuse; Force Single Sided always on) | |
Wrapper | PARTIAL (without Ignore Objects in Secondary, Caustics Affect) | |
Subsurface Scattering | ||
Bump | ||
VRscan | ||
Hair | ||
Toon | ||
Multi Material |
Textures
Bitmap6 | (without filtering and Environment texture placement) | |
Color | ||
Temperature | ||
Gradient | (without Environment texture placement) | |
Sky | (without Caustics) | |
Color Correction | ||
Spline Curve | ||
Bezier Curve | ||
Simple Mix | ||
Mix (Value) | ||
Mix (Operator) | ||
Mix (Map) | (except Mix Curve) | |
Multi-Sub3 | ||
Tri-Planar | ||
Checker | (except Environment texture placement) | |
Grid | (except Environment texture placement) | |
Tiles | (except Environment texture placement) | |
Cloth | (except Environment texture placement) | |
Leather | (except Environment texture placement) | |
Bulge | (except Environment texture placement) | |
UVW | (without Environment) | |
Water 8 | (without Environment) | |
Noise A | (except Environment texture placement) | |
Noise B | (except Environment texture placement) | |
Cellular | (except Environment texture placement) | |
Marble | (except Environment and 3D World texture placement) | |
Splat | (except Environment and 3D World texture placement) | |
Smoke | (except Environment texture placement) | |
Stucco | (except Environment and 3D World texture placement) | |
Rock | (except Environment and 3D World texture placement) | |
Granite | (except Environment and 3D World texture placement) | |
Speckle | (except Environment and 3D World texture placement) | |
Edges | ||
Falloff 2 | ||
Fresnel | ||
VRayDirt 3 | (without Ignore Self Occlusion) | (without Ignore Self Occlusion) |
Curvature | ||
UVW Placement | PARTIAL (except Environment and partial support of bitmap textures) |
Render Elements
Atmosphere | ||
Background | ||
Bump Normals | ||
Caustics |
Contours | ||
Cryptomatte |
Denoiser | ||
Diffuse | ||
DR Bucket | ||
ExtraTex | ||
Geometry Normals | ||
Global Illumination | ||
Lighting | ||
Lighting Analysis | PARTIAL (Luminance only) | |
Light Mix | ||
Material ID Color | ||
Material ID Number | ||
Material Random Color | ||
Matte Shadow | ||
MultiMatte | ||
Object ID | ||
Raw GI | ||
Raw Light | ||
Raw Reflection | ||
Raw Refraction | ||
Raw Shadow | ||
Raw Total Light | ||
Reflection | ||
Reflection Filter | ||
Refraction | ||
Refraction Filter | ||
Render ID | ||
Sample Rate | ||
Self Illumination | ||
Shadows | ||
Specular | ||
Total Light | ||
Z-Depth |
3rd-party plugins
Bongo 7 | ||
Cloud support for Bongo | – | – |
HDR Light Studio | ||
Cloud support for HDR Light Studio | ||
Archvision RPC | ||
Cloud support for Archvision RPC | ||
Rhino Nature |
Enscape
Enscape materials | PARTIAL | PARTIAL |
Enscape geometry assets | ||
Enscape material keywords |
Footnotes
1 – Displacement results between CPU and GPU rendering may differ slightly because of Pre-tessellation and Cache Normal settings.
2 – Only some procedural textures are supported by V-Ray GPU renderer when used for Bump mapping (f.e. noise and mix maps are supported).
3 – These plug-ins are only partially supported on GPU.
4 – For now only Lighting, GI, Reflection, Refraction, Bump Normals, Self Illumination, Diffuse Filter, Reflection Filter, Refraction Filter, Specular, ZDepth, Normals, Multi Matte and Light Select (GI, reflection, and refraction included) are supported.
5 – RPC are not supported in Interactive rendering mode. Changes done to the RPC model will not be visible in Interactive mode. Please note, that loading RPC models may take substantial time.
6 – The playback options are currently not supported.
7 – Bongo animation is exported as a series of still frames instead of animation frames. Due to this behavior, Motion Blur effect is not supported.
8 – The Water texture is used only for displacement.
- CUDA engine supports map channels from 0 to 15.
- CUDA engine only supports normal maps in tangent space.
- Difference between V-Ray and V-Ray GPU are expected when rendering objects with opacity/translucency modifications.
- When a material is not directly applied to an object or layer but instead only referenced by another asset, e.g. a Proxy Mesh material, and it is introduced through a worksession import it will not be imported if a naming conflict occurs with a pre-existing material. This is due to a Rhino SDK limitation.
