« Previous Version 5 Next »
This page provides information about V-Ray for Revit Public APIs.
V-Ray for Revit Public API is a gRPC server application that allows clients to programmatically read and configure V-Ray for Revit's properties and export V-Ray Scenes.
Download V-Ray for Revit Public Api Documentation
Download Public API Client zip
Download public_api.proto
Service Definition (public_api.proto)
V-Ray for Revit Public API provides the public_api.proto file, which represents the service definition and protocol format. Alongside the .proto file, two auto-generated C# files are provided - PublicApi.cs and PublicApiGrpc.cs. These two files contain the C# classes for all requests, responses, messages, and enums. The public_api.proto can be used to generate a binding in a language different from C# and develop a client in any of the supported languages.
service ApiServer {
rpc GetProjectName (GetProjectNameRequest) returns (GetProjectNameResponse);
rpc GetProjectChangedNotificationStream(GetProjectChangedNotificationStreamRequest) returns (stream ProjectChangedNotification);
rpc GetViews(GetViewsRequest) returns (GetViewsResponse);
rpc SelectView(SelectViewRequest) returns (SelectViewResponse);
rpc SetBatchRenderView(SetBatchRenderViewRequest) returns (SetBatchRenderViewResponse);
rpc GetProperties(GetPropertiesRequest) returns (GetPropertiesResponse);
rpc GetProperty(GetPropertyRequest) returns (GetPropertyResponse);
rpc SetProperty(SetPropertyRequest) returns (SetPropertyResponse);
rpc ExportVRScene(ExportVRSceneRequest) returns (ExportVRSceneResponse);
rpc GetVRayMaterials(GetVRayMaterialsRequest) returns (GetVRayMaterialsResponse);
rpc SaveVRayMaterialToFile (SaveVRayMaterialToFileRequest) returns (SaveVRayMaterialToFileResponse);
GetProjectName
GetProjectName is a unary RPC that sends a single GetProjectNameRequest to the server and gets a single GetProjectNameResponse back. It is used to obtain the name of the currently active project in Revit.
message GetProjectNameRequest {
google.protobuf.Empty empty = 1;
  • GetProjectNameRequest has no properties.
message GetProjectNameResponse {
bool success_status = 1;
string message = 2;
string project_name = 3;
  • success_status: A boolean indicating whether the RPC succeeded.
  • message: A string containing an error message in case the RPC failed for some reason.
  • project_name: The name of the project that is currently active in Revit.
GetProjectChangedNotificationStream is a server streaming RPCs where the client sends a GetProjectChangedNotificationStreamRequest to the server and gets a stream to read a sequence of ProjectChangedNotification messages back. It is used to receive a notification each time the active project in Revit changes.
message GetProjectChangedNotificationStreamRequest {
  • GetProjectChangedNotificationStreamRequest has no properties.
message ProjectChangedNotification {
string project_name = 1;
  • project_name: A string containing the name of the project that is currently active in Revit.
GetViews
GetViews is a unary RPC that sends a single GetViewsRequest to the server and gets a single GetViewsResponse back. It is used to obtain the names and unique ids of all 3D Views in the project. This information is later used when selecting a view for export.
GetViewsRequest
message GetViewsRequest {
  • GetViewsRequest has no properties.
GetViewsResponse
message GetViewsResponse {
string message = 2;
ViewMap view_map = 3;
  • view_map:ViewMap containing information about all 3D Views in the active project.
ViewMap
message ViewMap {
map<string, View> values = 1;
  • values: A map containing all views, where the key is the unique id of the View, and the value is the View itself.
View
message View {
string unique_id = 1;
string name = 2;
bool batch_render = 3;
  • unique_id: A string in GUID format that represents the unique id of the view.
  • name: A string containing the name of the view, i.e. what the user sees in Revit.
  • batch_render: A boolean specifying whether this view will be rendered as part of Batch Render.
SelectView
SelectViewis a unary RPC that sends a single SelectViewRequest to the server and gets a single SelectViewResponse back. It is used to select a view before exporting a V-Ray Scene.
SelectViewRequest
message SelectViewRequest {
  • unique_id: A string in GUID format that represents the unique id of the view. This is the same string that is obtained with the
GetViews RPC.
SelectViewResponse
message SelectViewResponse {
string message = 2;
SetBatchRenderView
SetBatchRenderViewis a unary RPC that sends a singleSetBatchRenderViewRequest to the server and gets a singleSetBatchRenderViewResponseback. It is used to specify whether the view will be rendered in a Batch Render.
message SetBatchRenderViewRequest {
bool batch_render = 2;
  • unique_id: A string in GUID format that represents the unique id of the view. This is the same string that is obtained with the GetViews RPC.
  • batch_render: A boolean value specifying whether the view will be rendered in a Batch Render.
string message = 2;
GetProperties
GetPropertiesis a unary RPC that sends a single GetPropertiesRequest to the server and gets a single GetPropertiesResponse back. It is used to get all V-Ray properties for the active project.
message GetPropertiesRequest {
  • GetPropertiesRequest has no properties.
message GetPropertiesResponse {
string message = 2;
PropertyMap property_map = 3;
  • property_map: A PropertyMap containing all properties of the active project.
PropertyMap
message PropertyMap {
map<string, Property> values = 1;
  • values: A map containing all properties, where the key is the unique name of the Property, and the value is the Property itself.
Property
message Property {
string unique_name = 1;
string readable_name = 2;
string type = 3;
PropertyCategory category = 4;
PropertyValue value = 5;
  • unique_name: A string that contains the unique name of the property.
  • readable_name: A string that contains the human-friendly readable name of the property.
  • type: A string containing the type of the property, i.e. bool, int, string, etc.
  • category: A PropertyCategory containing the category of the property, i.e. Camera, Environment, etc.
  • value: A PropertyValue containing the value of the property.
PropertyCategory
enum PropertyCategory {
Global = 0;
Material = 1;
Environment = 2;
Camera = 3;
Local = 4;
Swarm = 5;
Channel = 6;
Proxy = 7;
VRayMaterial = 8;
  • PropertyCategory is enumeration that contains all possible property categories. Currently, the V-Ray for Revit Public API returns only properties from Camera, Channel, Environment, and Local categories.
PropertyValue
message PropertyValue {
oneof value
bool bool_value = 1;
int32 int_value = 2;
float float_value = 3;
string string_value = 4;
LightingAnalysisQuantity LightingAnalysisQuantity_value = 5;
LightingAnalysisScale LightingAnalysisScale_value = 6;
LightingAnalysisDisplay LightingAnalysisDisplay_value = 7;
DenoiserMode DenoiserMode_value = 8;
DenoiserEngine DenoiserEngine_value = 9;
DenoiserRadiusType DenoiserRadiusType_value = 10;
VRayRenderEngine VRayRenderEngine_value = 11;
VRayResolutionRatio VRayResolutionRatio_value = 12;
VRayResolutionDPIType VRayResolutionDPIType_value = 13;
VRayResolutionPrinterUnit VRayResolutionPrinterUnit_value = 14;
EnvironmentType EnvironmentType_value = 15;
ScreenPlacementType ScreenPlacementType_value = 16;
BackgroundType BackgroundType_value = 17;
VRaySceneQuality VRaySceneQuality_value = 18;
VRayImageSamplerType VRayImageSamplerType_value = 19;
VRayGIEngine VRayGIEngine_value = 20;
VRayLightEvaluation VRayLightEvaluation_value = 21;
VRayCameraMode VRayCameraMode_value = 22;
VRayCameraStereoLayout VRayCameraStereoLayout_value = 23;
VRayCameraFocusSource VRayCameraFocusSource_value = 24;
LightMixGroupBy LightMixGroupBy_value = 25;
VRaySkyModel VRaySkyModel_value = 26;
VolumeVRayToonWidthUnits VolumeVRayToonWidthUnits_value = 27;
AColor AColor_value = 28;
Color Color_value = 29;
  • value: Contains oneof the possible values for a property depending on its type.
GetProperty
GetProperty is a unary RPC that sends a single GetPropertyRequest to the server and gets a single GetPropertyResponse back. It is used to get a single V-Ray property from the active project.
GetPropertyRequest
message GetPropertyRequest {
GetPropertyResponse
message GetPropertyResponse {
string message = 2;
Property property = 3;
  • property: A Property instance representing the requested property.
SetProperty
SetProperty is a unary RPC that sends a single SetPropertyRequest to the server and gets a single SetPropertyResponse back. It is used to set a single V-Ray property in the active project.
SetPropertyRequest
message SetPropertyRequest {
PropertyValue value = 2;
  • value: A PropertyValue containing the value to be set to the property.
SetPropertyResponse
message SetPropertyResponse {
string message = 2;
ExportVRScene
ExportVRScene is a unary RPC that sends a single ExportVRSceneRequest to the server and gets a single ExportVRSceneResponse back. It is used to export a V-Ray Scene of the currently selected 3D View.
message ExportVRSceneRequest {
string export_file_path = 1;
bool export_compressed = 2;
bool export_hex_format = 3;
bool export_as_archive = 4;
  • export_file_path: A string containing the absolute path where the V-Ray Scene should be exported.
  • export_compressed: A boolean indicating whehter to compress plugin property values of lists. Requires export_hex_format to be true.
  • export_hex_format: A boolean indicating whether to use hex format for arrays and transforms in the V-Ray Scene.
  • export_as_archive: A boolean indicating whether to export the V-Ray Scene as a 7-Zip archive along with all referenced assets, i.e. textures, HDRs, images, etc.
message ExportVRSceneResponse {
string message = 2;
  • message: If the RPC succeeded, this message would contain the actual path of the exported scene. If the RPC failed, this would be a string containing an error message.
GetVRayMaterials
GetVRayMaterials is a unary RPC that sends a single GetVRayMaterialsRequest to the server and gets a single GetVRayMaterialsResponse back. It is used to obtain the names of all V-Ray materials in the project. This information is later used when saving a V-Ray material to a .vrmat file.
message GetVRayMaterialsRequest {
  • GetVRayMaterialsRequest has no properties.
message GetVRayMaterialsResponse {
string message = 2;
repeated string material_names = 3;
  • material_names: A repeated string field containing the names of all V-Ray materials in the project.
SaveVRayMaterialToFile is a unary RPC that sends a single SaveVRayMaterialToFileRequest to the server and gets a single SaveVRayMaterialToFileResponse back. It is used to save a V-Ray material along with all of its assets to the file system. When the material is saved, a folder named maps appears next to the .vrmat file. This folder contains all assets, i.e. textures, used by the material. Always keep the maps folder and the .vrmat file in the same folder.
message SaveVRayMaterialToFileRequest {
string material_name = 1;
string file_path = 2;
  • material_name: A string containing the name of the V-Ray material that should be saved.
  • file_path: A string containing the absolute path where the V-Ray Material should be saved.
message SaveVRayMaterialToFileResponse {
string message = 2;
  • message: If the RPC failed, this would be a string containing an error message.
Enums and custom types
enum LightingAnalysisQuantity {
LuminanceCD = 0;
IlluminanceLX = 1;
  • LuminanceCD: Uses the Illuminance of the rendered frame in lux.
  • IlluminanceLX: Uses the Luminance of the rendered frame in candelas.
enum LightingAnalysisScale {
Linear = 0;
Logarithmic = 1;
  • Linear: The colors are mapped in linear scale.
  • Logarithmic: The colors are mapped in logarithmic scale.
enum LightingAnalysisDisplay {
FalseColors = 0;
GridOverlay = 1;
  • FalseColors: Fills the frame with a gradient ranging from blue (low values) to red (high values). For the out of range values it uses, respectively, black and white.
  • GridOverlay: Displays the values at distinct grid points over the frame. They use the same grading colors.
DenoiserMode
enum DenoiserMode {
ReplaceRGB = 0;
DoNotCalculate = 1;
GenerateChannel = 2;
  • ReplaceRGB: Generates all render elements required for denoising, but does not compute a denoised version of the image, neither is the VRayDenoiser render element present.
  • DoNotCalculate: The VRayDenoiser channel is not present separately in the VFB. The effectsResult channel is generated with the denoised image.
  • GenerateChannel: The VRayDenoiser and effectsResult channels are generated.
DenoiserEngine
enum DenoiserEngine {
Default = 0;
NVIDIA = 1;
  • Default: Default V-Ray Denoiser
  • NVIDIA: NVidia Al Denoiser
DenoiserRadiusType
enum DenoiserRadiusType {
CustomType = 0;
Mild = 1;
Normal = 2;
Strong = 3;
  • CustomType: Allows the strength and radius parameters to be set to custom values.
  • Mild: Applies a subtler level of denoising than the Default preset.
  • Normal: Applies default denoising.
  • Strong: Applies a stronger level of denoising than the Default preset.
VRayRenderEngine
enum VRayRenderEngine {
CPU = 0;
GPU = 4;
RTX = 7;
  • CPU: CPU
  • GPU: CUDA(GPU)
  • RTX: RTX(GPU)
VRayResolutionRatio
enum VRayResolutionRatio {
Widescreen = 0;
Screen = 1;
Square = 2;
Picture = 3;
Landscape = 4;
Portrait = 5;
CropRegion = 6;
Custom = 7;
  • Widescreen: 16:9 - Widescreen
  • Screen: 8:5 - Screen
  • Square: 1:1 - Square
  • Picture: 4:3 - Picture
  • Landscape: 5:4 - Landscape
  • Portrait: 4:5 - Portrait
  • CropRegion: The default Aspect Ratio, which allows for rendering the exact boundary of Revit’s Crop Region.
  • Custom: Allows manual input of the proportions of the image.
enum VRayResolutionDPIType {
UnusedVRayResolutionDPIType = 0;
DPI75 = 75;
DPI96 = 96;
DPI150 = 150;
DPI300 = 300;
DPI600 = 600;
UnusedVRayResolutionDPIType: NEVER USE THIS VALUE. IT WAS INTRODUCED DUE TO PROTO SYNTAX LIMITATIONS.
  • DPI75: 75 dpi
  • DPI96: 96 dpi
  • DPI150: 150 dpi
  • DPI300: 300 dpi
  • DPI600: 600 dpi
enum VRayResolutionPrinterUnit {
Inches = 0;
Millimeters = 1;
  • Inches: Inches
  • Millimeters: Millimeters
EnvironmentType
enum EnvironmentType {
Sun = 0;
Dome = 1;
None = 2;
  • Sun: V-Ray Sun
  • Dome: V-Ray Dome Light
  • None: No V-Ray Lights
ScreenPlacementType
enum ScreenPlacementType {
ScreenPlacement = 0;
SphericalPlacement = 1;
  • ScreenPlacement: Screen Placement
  • SphericalPlacement: SphericalPlacement
BackgroundType
enum BackgroundType {
NoBackground = 0;
CustomBackground = 1;
RevitBackground = 2;
  • NoBackground: No Background
  • CustomBackground: Custom Background
  • RevitBackground: Revit Background
VRaySceneQuality
enum VRaySceneQuality {
Draft = 0;
Low = 1;
Medium = 2;
High = 3;
VeryHigh = 4;
  • Draft: Draft Quality
  • Low: Low Quality
  • Medium: Medium Quality
  • High: High Quality
  • VeryHigh: VeryHigh Quality
enum VRayImageSamplerType  {
UnusedVRayImageSamplerType = 0;
Buckets = 1;
Progressive = 3;
  • UnusedVRayImageSamplerType: NEVER USE THIS VALUE. IT WAS INTRODUCED DUE TO PROTO SYNTAX LIMITATIONS.
  • Buckets: This sampler takes a variable number of samples per pixel based on the difference in intensity between the pixel and its neighbors.
  • Progressive: This is the default image sampler set in V-Ray for Revit. It renders the entire image progressively in passes.
VRayGIEngine
enum VRayGIEngine {
IrradianceMap = 0;
BruteForce = 2;
LightCache = 3;
  • IrradianceMap: Indirect Illumination is computed for a few points in a scene. The remaining points use interpolated values. It is built adaptively but is view-dependent.
  • BruteForce: The simplest approach where indirect illumination is computed individually for each shaded surface point.
  • LightCache: Traces multiple paths from the camera. It is view-dependent, but handles details and corners better.
VRayLightEvaluation
enum VRayLightEvaluation {
Full = 0;
Adaptive = 2;
  • Full: Full light evaluation.
  • Adaptive: Optimizes the sampling of lights in scenes with many lights.
VRayCameraMode
enum VRayCameraMode {
Standard = 0;
Orthogonal = 7;
SphericalPanorama = 9;
Cube = 10;
  • Standard: A traditional pinhole camera.
  • Orthogonal: An orthogonal camera.
  • SphericalPanorama: Spherical camera with independent horizontal and vertical FOV selection that is useful for generating latlong images for spherical VR use.
  • Cube: A variant of the Box camera with the cube sides arranged in a single row. Unlike the Box camera output, Cube6x1 does not produce an empty space in the output image and is useful for generating cubic VR output.
enum VRayCameraStereoLayout {
UnusedVRayCameraStereoLayout = 0;
SideBySide = 1;
TopBottom = 2;
  • UnusedVRayCameraStereoLayout: NEVER USE THIS VALUE. IT WAS INTRODUCED DUE TO PROTO SYNTAX LIMITATIONS.
  • SideBySide: Stereoscopic images are rendered Side-by-side.
  • TopBottom: Stereoscopic images are rendered Top-bottom.
enum VRayCameraFocusSource {
FixedDistance = 0;
FixedPoint = 2;
  • FixedDistance: Fixes the camera focus to the Focus Distance value.
  • FixedPoint: The focus distance is automatically calculated before the rendering starts, and equals the distance between the camera position and the 3D point selected using the Pick Focus Point Command from the toolbar menu. If no point has been selected, the camera target is used as a default point instead.
AColor
message AColor {
float r = 1;
float g = 2;
float b = 3;
float alpha = 4;
  • r: Value between 0.0 and 1.0 for the red color.
  • g: Value between 0.0 and 1.0 for the green color.
  • b: Value between 0.0 and 1.0 for the blue color.
  • alpha: Value between 0.0 and 1.0 for the alpha.
Color
message Color {
float r = 1;
float g = 2;
float b = 3;
Code Samples (C#)
Obtaining the Server Port
In order to connect to the Public API Server, the client needs to know which port the server is running on. When the the V-Ray for Revit Public API Server starts, it chooses a random free port to start on and writes this information in the C:\Users\%USERPROFILE%\AppData\Roaming\Chaos Group\V-Ray for Revit 20XX\config.json, where XX is the Revit version. When your code is running from within a Revit Addin, use the current process id (i.e. of Revit.exe) to locate the V-Ray for Revit API Server running in the same instance of Revit.exe. When your code is running from a standalone application (console app, WPF app, etc.) and there is more than one instance of the same Revit.exe version running, it is up to you to decide to which instance of V-Ray for Revit API Server to connect to.
Here is how the apiServers entry might look like in config.json:
"apiServers": [
"PID": 22920,
"port": 58538
"PID": 14792,
"port": 58611
And here is how you can obtain the port, depending on whether your code is executing from within a Revit Addin or from standalone application:
private const int RevitVersion = 2020;
private static readonly string ConfigJsonPath = Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData),
$"Chaos Group\\V-Ray for Revit {RevitVersion}", "config.json");
private static int GetServerPort()
var runningInRevitAddon = true;
using (var reader = new StreamReader(ConfigJsonPath))
var json = JObject.Parse(reader.ReadToEnd());
var apiServers = json["apiServers"] as JArray;
if (apiServers != null && apiServers.Count > 0)
JObject apiServer;
if (runningInRevitAddon)
apiServer = apiServers.OfType<JObject>().SingleOrDefault(jo => (int)jo["PID"] == Process.GetCurrentProcess().Id);
else
apiServer = apiServers.OfType<JObject>().FirstOrDefault();
if (apiServer != null)
return (int)apiServer["port"];
return -1;
When the Public API Server is shutdown, i.e. the user closes Revit, its entry is deleted from config.json.
Note that the code above uses the Newtonsoft Json.NET library, but you can read the json file in any way that you prefer.
Connecting to the Server
public async Task<bool> ConnectAsync()
var serverPort = GetServerPort();
if (serverPort != -1)
this.channel = new Channel($"localhost:{serverPort}", ChannelCredentials.Insecure);
var deadline = DateTime.UtcNow.AddSeconds(1);
try
await this.channel.ConnectAsync(deadline);
return true;
catch (TaskCanceledException)
return false;
else
Debug.WriteLine("Public API Server has not started yet!");
return false;
GetServerPortis from the previous code snippet.
Get the active project name
public async Task<string> GetProjectNameAsync()
try
var client = new ApiServerClient(this.channel);
var response = await client.GetProjectNameAsync(new GetProjectNameRequest());
if (response.SuccessStatus)
return response.ProjectName;
else
MessageBox.Show(response.Message, "Error", MessageBoxButton.OK, MessageBoxImage.Error);
return string.Empty;
catch (RpcException e)
Debug.WriteLine(e);
ApiServerClientGetProjectNameRequest, and GetProjectNameResponse are all classes auto-generated by the proto-buffer compiler.
Get all 3D Views from the active project
public async Task<IEnumerable<View>> GetViewsAsync()
try
var response = await client.GetViewsAsync(new GetViewsRequest());
return response.ViewMap.Values.Values;
else
return Enumerable.Empty<View>();
Debug.WriteLine(e);
ApiServerClientGetViewsRequest, and GetViewsResponse are all classes auto-generated by the proto-buffer compiler.
Select a 3D View
public async Task<bool> SelectViewAsync(string uniqueId)
try
var response = await client.SelectViewAsync(new SelectViewRequest() { UniqueId = uniqueId });
return true;
else
return false;
Debug.WriteLine(e);
return false;
uniqueId is one of the unique ids of the views retrieved in the previous code snippet.
Get all properties
public async Task<IEnumerable<Property>> GetPropertiesAsync()
try
var response = await client.GetPropertiesAsync(new GetPropertiesRequest());
return response.PropertyMap.Values.Values;
else
return Enumerable.Empty<Property>();
Debug.WriteLine(e);
ApiServerClientGetPropertiesRequest, and GetPropertiesResponse are all classes auto-generated by the proto-buffer compiler.
Get a single property
public async Task<Property> GetPropertyAsync(string uniqueName)
try
var response = await client.GetPropertyAsync(new GetPropertyRequest() { UniqueName = uniqueName });
return response.Property;
else
return null;
Debug.WriteLine(e);
return null;
uniqueName is one of the unique names of the properties retrieved in the previous code snippet.
Set property
 public async Task<bool> SetPropertyAsync(string uniqueName, PropertyValue propertyValue)
try
var request = new SetPropertyRequest()
UniqueName = uniqueName,
Value = propertyValue
var response = await client.SetPropertyAsync(request);
return true;
else
return false;
Debug.WriteLine(e);
return false;
uniqueName is one of the unique names of the properties retrieved in the Get all properties code snippet. propertyValue is a PropertyValue initialized with the correct type of value, based on the property type. The 7 code snippets below use the method defined in this code snippet.
Set bool property
var uniqueName = "GlobalArtificialLightsEnabled";
var propertyValue = new PropertyValue() { BoolValue = true };
SetPropertyAsync(uniqueName, propertyValue);
Set int property
var uniqueName = "customResolutionWidth";
var propertyValue = new PropertyValue() { IntValue = 800 };
Set float property
var uniqueName = "GlobalArtificialLightsIntensity";
var propertyValue = new PropertyValue() { FloatValue = 2.0f };
Set string property
var uniqueName = "backgroundImagePath";
var propertyValue = new PropertyValue() { StringValue = "C:\myimage.png" };
Set enum property
var uniqueName = "environmentType";
var propertyValue = new PropertyValue() { EnvironmentTypeValue = EnvironmentType.Dome };
Set AColor property
var uniqueName = "EnvFogColor";
var propertyValue = new PropertyValue() { AColorValue = new AColor() { R = 0.5f, G = 0.5f, B = 0.5f, Alpha = 1.0f } };
Set Color property
var uniqueName = "SunFilterColor";
var propertyValue = new PropertyValue() { ColorValue = new Color() { R = 0.5f, G = 0.5f, B = 0.5f } };
Export V-Ray Scene
public async Task<Tuple<bool, string>> ExportVRSceneAsync(string exportFilePath, bool exportAsArchive, bool exportCompressed, bool exportHexFormat)
try
try
var response = await client.ExportVRSceneAsync(new ExportVRSceneRequest()
ExportFilePath = exportFilePath,
ExportAsArchive = exportAsArchive,
ExportCompressed = exportCompressed,
ExportHexFormat = exportHexFormat
// If the export was successfull, response.Message will contain the
// actual file path of the exported V-Ray Scene
return new Tuple<bool, string>(response.SuccessStatus, response.Message);
catch (TaskCanceledException e)
Debug.WriteLine(e);
return new Tuple<bool, string>(false, e.ToString());
Debug.WriteLine(e);
await this.ShutdownAsync();
ApiServerClientExportVRSceneRequest, andExportVRSceneResponse are all classes auto-generated by the proto-buffer compiler.
Get all V-Ray Material Names
public async Task<IEnumerable<string>> GetVRayMaterialsAsync()
try
var response = await client.GetVRayMaterialsAsync(new GetVRayMaterialsRequest());
return response.MaterialNames;
else
return Enumerable.Empty<string>();
Debug.WriteLine(e);
ApiServerClientGetVRayMaterialsRequest, and GetVRayMaterialsResponse are all classes auto-generated by the proto-buffer compiler.
Save V-Ray Material to File
public async Task<Tuple<bool, string>> SaveVRayMaterialToFileAsync(string materialName, string filePath)
try
try
var response = await client.SaveVRayMaterialToFileAsync(new SaveVRayMaterialToFileRequest()
MaterialName = materialName,
FilePath = filePath
Debug.WriteLine(e);
Debug.WriteLine(e);
ApiServerClientSaveVRayMaterialToFileRequest, and SaveVRayMaterialToFileResponse are all classes auto-generated by the proto-buffer compiler.
Listen for project changed
public async void ListenForProjectChangedAsync()
try
using (var call = client.GetProjectChangedNotificationStream(new GetProjectChangedNotificationStreamRequest(), null, null, this.cts.Token))
while (await call.ResponseStream.MoveNext())
var projectName = call.ResponseStream.Current.ProjectName;
Debug.WriteLine("Project has changed to " + projectName);
Debug.WriteLine(e);
Resources
V-Ray for Revit Public API Client Reference Implementation
After you install V-Ray for Revit, you can find a reference implementation of a C# client at the following location: C:\Program Files\Chaos Group\V-Ray\V-Ray for Revit\PublicAPIClient.zip. Unzip the archive somewhere on your machine and explore the Visual Studio solution. Most of the code snippets above are taken directly from this sample application. The sample application is just a reference implementation and is provided as is.
