This page provides information about the Back to Beauty Render Element in V-Ray for SketchUp.
The V-Ray Back to Beauty Render Element expands as all beauty elements for the actual rendering. In the VFB, this render element creates a folder in Composite named Back To Beauty containing all elements with the appropriate blend modes. The elements that are used for the beauty rebuild are - Background, Lighting, Global Illumination, Reflection, Specular, Refraction, Self Illumination, Caustics, Subsurface Scattering and Atmosphere.
When selecting the Affect All channels option of Generic material, be aware that the information of the respective component affects all render elements, therefore the Back to Beauty composition does not match the RGB result from the renderer.
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Back to Beauty
||V-Ray Asset Editor|| > Create Asset (left-click) > Render Elements > Back to Beauty
Denoise – Specifies whether to denoise this render element.
Compositing
(Click on the image to see it in full size)
