This page provides details on the system requirements to install V-Ray Standalone.
Windows
Please make sure that your system fulfills these requirements before installing V-Ray.
Processor | Intel 64*, AMD64 or compatible processor with SSE4.2 support |
RAM | Minimum 8 GB RAM, recommended 64 GB RAM Actual amount required will vary with scene requirements. |
Operating System | Windows 8.1, Windows 10, and Windows 11 |
USB Port | Required for customers using legacy hardware lock, preferably USB 2.0 |
TCP/IP | Only IPv4 required for distributed rendering is supported. IPv6 is currently not supported |
HDD | 0.9 GB Hard Disk Space |
GPU Support | NVIDIA CUDA with minimum required compute capability 5.2**: Maxwell-, Pascal-, Volta-, Turing- and Ampere-based NVIDIA card(s); NVIDIA RTX with compute capability 5.2**: RTX cards with latest recommended video driver; 2GB VRAM V-Ray Production Denoiser: AMD or NVIDIA GPU supporting OpenCL 1.2; NVIDIA AI Denoiser: Maxwell-, Pascal-, Volta-, Turing-, and Ampere-based NVIDIA card with latest recommended video driver |
* Windows 11 is required for running Intel Alder Lake processors.
** CUDA compute capability and card reference
Linux
Please make sure that your system fulfills these requirements before installing V-Ray. Note that V-Ray is only supported for 64 bit operating systems.
Processor | Intel 64, AMD64 or compatible processor with SSE4.2 support |
RAM | Minimum 8 GB RAM, recommended 64 GB RAM Larger cache memory, higher memory bandwidth and more cores are better. |
Operating System | Red Hat® Enterprise Linux® 7.2 WS, or Red Hat ® Enterprise Linux® 8, or CentOS 7.2 (64bit) |
USB Port | Required for hardware lock, preferably USB 2.0 |
TCP/IP | Only IPv4 is supported. IPv6 is currently not supported |
HDD | 1 GB Hard Disk Space |
GPU Support | NVIDIA CUDA: Maxwell-, Pascal-, Volta-, Turing-, and Ampere-based NVIDIA card(s) with the latest recommended video driver; NVIDIA RTX: RTX cards with the latest recommended video driver V-Ray Production Denoiser: AMD or NVIDIA GPU supporting OpenCL 1.2; NVIDIA AI Denoiser: Maxwell-, Pascal-, Volta-, Turing-, or Ampere-based NVIDIA card with the latest recommended video driver The minimum required compute capability is 5.2* |
macOS
Operating System | Apple® Mac OS® X 10.9 Mavericks or later |
HDD | 0.7 GB Hard Disk Space |
V-Ray GPU works only with C++/CPU devices under macOS. V-Ray GPU can still be used in distributed rendering where a macOS machine runs the CUDA engine on a CPU device together with Windows/Linux machine(s) running CUDA engine on GPU device(s).
