This page gives information about the Diffuse Filter Render Element, one of the basic render elements used to form many other render elements.
The Diffuse Filter Render Element shows the colors and textures used in materials, flatly applied to objects with no lighting information. The colors are the actual colors set in the material definition, and each texture appears as it does in the texture (file) itself. There are no highlights or shadows, and any background image is not included.
Other render elements that include colors from materials are said to include the diffuse contribution or the diffuse component of the rendered scene. The Diffuse Filter Render Element contributes this diffuse component; any render element that includes this diffuse component is a combination of VRayDiffuseFilter and other render element(s).
Note that the Diffuse Filter Render Element is affected by reflection and refraction combined weight. 1
This render element is, by itself, useful for making overall adjustments and enhancements to colors and textures during compositing.
VRayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
Common Uses
The Diffuse Filter Render Element is useful for changing the appearance of many passes, when it is combined with Raw render passes (like VRayRawGlobalIllumination, VRayRawLighting, etc.).
In the example, the Diffuse Filter is blended with the Raw Global Illumination RE in Multiply mode to provide the Global Illumination element. This way, color correction can be performed upon the raw pass, without the actual diffuse colors changing, making it possible to tint a pass in a realistic way without re-rendering.
The Diffuse Filter is a very useful render element due to the number of raw passes with which it can be combined, giving the ability to manipulate many areas of the render at the composite level. The Diffuse Filter pass can also be color-corrected on its own, as shown in the example. In this case, a Multimatte RE is used to isolate the cloth on the sofa. The Diffuse Filter RE is used to change the cloth's color from yellow to blue. This method avoids tinting the lighting or shadowing of the scene.
1 - This means that reflective objects with solid diffuse color appear differently according to the view angle. The actual diffuse color is displayed only if the VRayRawDiffuse Render Element is used.
