©BBB3viz
This page gives information on the Subsurface Scattering Render Element.
The VRaySSS2 Render Element stores information calculated from Subsurface Scattering materials (VRayAlSurfaceMtl and VRayFastSSS2).  This render element can then be used to enhance or color-correct just the subsurface scattering component of the image during the compositing process.
VRayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise –  Specifies whether to denoise this render element.
Common Uses
The Subsurface Scattering Render Element is useful for changing the appearance of SSS2 elements, after rendering, in a compositing or image editing software. In the example, the scattering color is changed to red using the SSS2 RE. See the render before and after compositing.
Before
After
Compositing Formula
The VRaySSS2 Render Element is added to the Beauty composite to form the final image.
