This page provides information about the mouse and key shortcuts in Chaos Vantage.
Vantage provides a list of mouse and key shortcuts for easier navigation and commands execution. The navigation can be set to work as in 3ds Max, SketchUp or Maya. This can be set from the Navigation Preset dropdown.
The mouse and key shortcuts are divided in several groups:
Icon | Description |
General shortcuts | |
Navigation shortcuts | |
Camera shortcuts | |
Tools shortcuts | |
Selection shortcuts | |
Animation editor shortcuts |
To see the full list of shortcut keys in Chaos Vantage, go to Edit > Mouse and Key Shortcuts.
To understand the shortcuts below, you should assume the following abbreviations:
Abbreviation | Control |
LMB | Left Mouse Button |
RMB | Right Mouse Button |
MMB | Middle Mouse Button |
[3]/[S]/[M] | Shortcut depending on navigation preset: [3] - 3ds Max [S] - Sketchup [M] - Maya |
Shortcuts which are not greyed out can be edited. New keys or combination of keystrokes with modifiers can be assigned by using LMB click on the shortcut or RMB click > Edit. Additional options for shortcuts are Delete, which removes the shortcut and Reset, which restores it to default value.
General Shortcuts
Command | Shortcut |
Toggle Interface | Ctrl+` |
Toggle Fullscreen Mode | Alt+Return |
Toggle Fullscreen Mode and Interface | Alt+` |
Flip Up Axis Z/Y | Y |
Pause Rendering | Pause |
Frame Selected/Scene | [3] Z [S] Z [M] F |
Navigation Shortcuts
Dolly Camera Sideways | [3] MMB [S] Shift+MMB [M] Alt+MMB |
Orbit Camera | [3] Alt+MMB [S] MMB [M] Alt+LMB |
Fine/Smooth Camera Zoom | [3] Ctrl+Alt+MMB [S] [M] Alt+RMB |
Toggle First Person Mode | ` |
Toggle Camera Collision | C |
Camera Move Forward (when in First Person mode) | W |
Camera Move Backward (when in First Person mode) | S |
Camera Move Left (when in First Person mode) | A |
Camera Move Right (when in First Person mode) | D |
Camera Move Up (when in First Person mode) | E |
Camera Move Down (when in First Person mode) | Q |
Camera Move Faster (when in First Person mode) | Shift+ |
Camera Ignore Collisions (when in First Person mode) | Ctrl+ |
Camera Pan Up (when in First Person mode) | Up |
Camera Pan Down (when in First Person mode) | Down |
Camera Pan Left (when in First Person mode) | Left |
Camera Pan Right (when in First Person mode) | Right |
First person mode is also enabled while pressing the RMB. All camera movement related actions (Move Forward, Move Backward, Move Left, Move Right, Move Up, Move Down, Move Faster, Ignore Collisions, Pan Up, Pan Down, Pan Left, Pan Right) are accessible while RMB is pressed.
Camera Shortcuts
Change Focus Distance | Ctrl+Alt+LMB |
Change FOV | [3] Alt+RMB [S] Alt+RMB [M] |
Roll Camera | Ctrl+MMB |
Toggle Camera Recording | Ctrl+Shift+R |
Undo Camera | Alt+Z |
Redo Camera | Alt+Shift+Z |
Level the Camera | X |
Save New Camera | Ctrl+K |
Overwrite Camera | Ctrl+Shift+K |
Switch to Home Camera | Home |
Switch to Next Camera | PgDown |
Switch to Previous Camera | PgUp |
Load Camera Slot | F1..F12 |
Tool Shortcuts
Select | Q |
Group Select | Shift+Q |
Translate | W |
Rotate | E |
Scale | R |
Pick Focus | T |
Snap | S |
Undo | Ctrl+Z |
Redo | Ctrl+Shift+Z |
Copy Viewport to Clipboard | Ctrl+C |
High Quality Render Setup | Ctrl+R |
Always On Top | Ctrl+Alt+T |
Selection Shortcuts
Make Selection Invisible | V |
Make Selection Visible | Shift+V |
Select Parent | Ctrl+Up |
Save Selection | Ctrl+0..9 |
Restore Selection | 0..9 |
Animation Shortcuts
Play/Pause Animation | Space |
Scroll though the timeline | Mouse wheel |
Zoom in/out of the timeline | Alt+Mouse wheel |
