This page gives details on the license setup for Chaos products.
Chaos License Server version 5.0 provides licensing of the Chaos products without the need for any physical devices to be plugged in your machine. It allows you to easily activate more licenses right after the purchase and provides a way to stay offline while using your products when you need to. It is still compatible with existing USB dongles, in case you need to use your licenses in this way. Overview
Interface
The License Server's interface is accessible in a web browser. See the License Server Interface page for more information.
Installation
The installer is fairly straightforward and easy to run, but if you need help, please see the Installing the License Server page for details on the process. This includes using your Chaos account to access your purchased licenses from anywhere online.
Activation
To activate your licenses, go to 127.0.0.1:30304 using your web browser and click Sing in from the ONLINE LICENSING menu. You will then be prompted to enter your username/email and password. Once the activation is successful, you will be able to see the list of your available licenses on the Chaos License Server home page.
Offline Activation and License Usage - Recommended for Machines Without Internet Access
You can still activate your License Server even without Internet connection. To do this you need to download an activation request file from your License Server. Use another machine with Internet connection to upload the file to my.chaosgroup.com where you log in with your Chaos account and generate an activation file. Upload the activation file to your License Server to activate it.
See also the Borrowing Licenses for Offline Use page for additional information.
USB Dongle usage
The Licensing system allows you to use seats associated with your Chaos account easily from anywhere you can log into over the internet. If you also have a USB dongle with Chaos product licenses attached to your computer, you can utilize those available licenses with the License Server. For more details on this process, please see the Dongle usage page.
In most situations, adjusting the Settings for the online licensing system is not necessary. But if you need to adjust something like your connection settings because you're using a Proxy server, you can get to these through the drop-down menu in the top right corner of the License Server webpage and choosing Settings. For more details on what settings are adjustable from this area, please see the Advanced Settings page.
Updating from License Server 3.0 to 5.0
If you are updating your licensing system from the previous setup to the new online system, no changes are required on the workstation or application side of your software. The online system replaces the existing dongle functionality without any additional steps needed on your part. There is no need to use the Change License Settings application to reconfigure your setup. If you have purchased online licenses, these can be activated for online usage in the new system right away.
