V-Ray lights are designed specifically to work with V-Ray and optimize its features. V-Ray also provides shadow options for standard 3ds Max lights, and utilities to assist in the lighting process.
While you can use 3ds Max standard lights with V-Ray, V-Ray includes a set of lights designed specifically for rendering with the V-Ray engine.
If you want to use the standard 3ds Max lights, you should use VRayShadow type in the Shadows section of the respective Standard light.
The V-Ray Light Meter utility helps evaluate the lighting in a scene so adjustments can be made to improve lighting.
Image courtesy of Sonny Ferian
Types of Lights
As with standard 3ds Max lights, you can create these lights using the Lights tab on the Command Panel. Depending on the scene and the effect you are trying to create with light, you might select to use only one type of light, or any combination of lights.
- Area lights are useful for simulating man-made light sources in an interior environment, such as lamps. An Area light can have any one of many different shapes: plane, disc, sphere, or the shape of a mesh object. A dome light, which creates light within a dome shape to create a traditional global illumination setup, is also considered an Area light.
- A Sun light is a spherical light source placed at a specific location which simulates the sun in the sky. A Sun light has some unique qualities. Check the VRaySun page for more information.
- Photometric lights are designed to simulate light sources exactly as they behave in real life by loading and using an IES (Illumination Engineering Society) file with details about the light's behavior, such as how the light passes through lenses and its intensity and falloff.
- Ambient light permeates a scene and illuminates from all angles equally without providing contrast.
Lighting Tools
The following tools are provided by V-Ray to assist with lighting:
The information that is presented by VRayLightMeter does not change or otherwise affect the lighting in the scene in any way; it only reports on it. This helper is intended to provide information so you can make adjustments to the scene's lighting at your own discretion.
- When the Store with irradiance map option is enabled on any V-Ray Light, it is then no longer treated as a direct light source and is not available within the Light Select Render Element.
