« Previous Version 47 Next »
Chaos Vantage , v1.8.2
Unable to render {include} The included page could not be found.
Chaos Vantage , v1.8.1
Chaos Vantage , v1.8.0
Chaos Vantage , v1.7.4
Chaos Vantage , v1.7.3
Chaos Vantage , v1.7.2
Chaos Vantage , v1.7.1
Chaos Vantage , v1.7.0
Chaos Vantage , v1.6.2
Chaos Vantage , v1.6.1
Chaos Vantage , v1.6.0
Chaos Vantage , v1.5.3
Chaos Vantage , v1.5.2
Chaos Vantage , v1.5.1
Chaos Vantage , v1.5.0
Chaos Vantage , v1.4.2
Chaos Vantage , v1.4.1
Chaos Vantage , v1.4.0
Chaos Vantage , v1.3.0
Chaos Vantage , v1.2.1
Chaos Vantage , v1.2.0
Chaos Vantage , v1.1.1
Chaos Vantage , v1.1.0
Chaos Vantage , v1.0.2
Chaos Vantage , v1.0.1
Chaos Vantage , v1.0.0
Project Lavina is now Chaos Vantage.
Project Lavina Beta, v0.6.0
Beta Release
Date - November 04, 2020
New Features
  • Experimental 3ds Max to Lavina live link
Texture
  • Support for Triplanar texture
UI
  • Light gizmos for easy selection of non-area lights when a transform tool is selected
Config .vrdx
  • Loading saved Lavina files(.vrdx) now loads associated .vrscenes
Modified
GPU
  • Improved out-of-memory protection for GPU resources
UI
  • Improved indicator for render state - RENDERING, PAUSED, CAM REC., LIVE LINK
Fixes
Camera
  • Issue when saving camera slot shortcut
  • 'Fill' option squashing image when using a portrait aspect ratio
Lights
  •  Non top level lights in a hierarchy can not be disabled
UI
  •  App window not returning to proper size after a spherical or cube offline render
Texture
  •  Opacity map not working when the texture's alpha channel is used
Project Lavina Beta, v0.5.1
Beta Release
Date - October 08, 2020
New Features
Camera
  • Added Rotation Focus method to Stereo Spherical and Stereo Cube 6x1 camera types
  • Add support for import of Exposure value in Physical Camera
Modified
.vrscenes
  • Improved handling of back face materials from V-Ray 5 for SketchUp .vrscenes
Fixes
UI
  •  Cloning selected objects also duplicate scene lights in Lights tab
CPU
  •  D3D error on machine with large cpu thread count
Project Lavina Beta, v0.5.0
Beta Release
Date - September 03, 2020
New Features
Camera
  • Added Cube 6x1, Spherical and Spherical Stereoscopic camera types to render images and sequences
Modified
  • Improved performance with GPUs set with NVlink connection
Fixes
Animation Editor
  •  Camera thumbnails in timelines are squashed with different aspect ratio
Camera
  • Camera jolts when navigating from a stored camera with a roll
  • Frame selected/scene shortcut doesn't work
  • Home camera not loading correct FOV
Texture
  •  Forest color texture importing black.
Project Lavina Beta, v0.4.4
Beta Release
Date - August 19, 2020
New Features
Camera
  • Tilt and shift corrections for Physical Camera
Modified Features
UX
  •  Color picker dialogue can be moved around
Fixes
.vrscene
  • Incorrect scaling when merging .vrscenes exported with different meter scale
Camera
  • Switching between stored cameras with different FOV results in a jump
Project Lavina Beta, v0.4.3
Beta Release
Date - August 03, 2020
New Features
Lights
  • Support for texture in V-Ray Plane/Rectangle light
  • Support for V-Ray Disk/Ellipse light
License Server
  • License server as part of the installation
GPU
  • GPU driver check for currently unsupported and recommended drivers
Modified Features
Camera
  •  Improved Camera roll navigation action
UX
  •  "Check for updates" button in Help menu
  • Build date and time info in About dialog
Fixes
Animation Editor
  •  Transient clip in animation editor cannot be selected or modified
  • Pivot point not moving with object when animated from imported .vrscene
Denoiser
  • Artifacts around very bright light source
  • Reflection artifacts when using two GPUs
Project Lavina Beta, v0.4.2
Beta Release
Date - July 22, 2020
Fixes
Video Driver
  • Startup error (D3D error) with 450 series NVidia drivers
Project Lavina Beta, v0.4.1
Beta Release
Date - July 10, 2020
Fixes
Camera
  •  Physical camera parameters not syncing when switching camera slots
  • Physical camera parameters scaling erroneously when loading from vrdx file
Animation Editor
  • Physical cameras not interpolating correctly in animation editor when using FoV
  • 'Aperture size' interpolation in animation editor
Denoiser
  • Denoiser issue when using more than one GPU
Project Lavina Beta, v0.4.0
New Features
Camera
  • Camera roll functionality
Material
  • Support for metalness (BRDFVrayMtl)
UI
  • Pivot point selection button to top toolbar
  • Mouse precision toggle button
MAXScript
Modified Features
Denoiser
  • Improved denoiser:
    • Details from small objects and shadows are less blurry
    • Reduced halo/bloom effect around objects
Animation Editor
  • Improved UX :
    • Increase the pickup radius for selecting thin areas - timeline marker, clip edges.
    • Make the rightmost 20px of a clip with two drag-able controls.
    • Transient clips are not resizable when dragged, only their position change.
    • Transient clips have a better thicker line indicator
    • Increase the limit of the "Def. duration" spinner to 1000 (approx. 10 sec @ 90fps )
Project Lavina Beta, v0.3.1
Beta Release
Date - July 01, 2020
Fixes
  • Imported animated sun from .vrscene not being animated in Lavina
Project Lavina Beta, v0.3.0
Beta Release
Date - June 26, 2020
New Features
  • Added Animation Editor (experimental)
  • Added Light grouping(instancing) on imported lights
  • Added support for V-Ray Sun and Sky models
  • Added Noise threshold option
  • Added Support for Simple(environment) light portal
  • Added support for CommonTexture and MappedTexture set of texture parameters: Crop, Place, AlphaSource, MonoChannelOutput, RGBChannelOutput, Invert, OutputAmount, Clamp, RGBOffset, RGBLevel
Modified Features
  • Improved Color Picker - interactive updates, color temperature, color presets, color range options
  • Improved UI:
    • Last snapshot render time information
    • Selecting a light focuses it in the light lister
  • Improved visual parity between Lavina and V-Ray
Project Lavina Beta, v0.2.3
Beta Release
Date - May 07, 2020
New Features
  • Added new Camera list with thumbnails and set, delete and reorder functionality
  • Added support for Directional, Omni and Spot lights from 3Ds Max
  • Added support for Instanced objects from Maya/Modo/Houdini
  • Added "Display to render ratio" control in the toolbar
Modified Features
  • Improved navigation - Selection Pivot Type
  • Improved denoiser - Artifacts with motion blur with fast moving objects are reduced
  • Improved denoiser - textures behind refractive objects are less blurry
  • Improved UI - RMB to reset value to default
Project Lavina Beta, v0.2.2
Beta Release
Date - April 09, 2020
New Features
  • Support for IES lights
  • Support for Spot lights from Maya/Modo/Katana/Cinema4D/Sketchup/Rhino
  • Object pivot import and manipulation
  • Move Pivot tool
  • Navigation target type option - Ray hit or Camera target
Modified Features
  • Improved navigation - gizmo for orbit pivot and zoom point
Bug Fixes
  • Fixed bug with rotation and scaling in local space
Project Lavina Beta, v0.2.1
Beta Release
Date - March 26, 2020
Modified Features
  • Improved denoiser blending - added simple adaptivity to raw/denoised blending to filter out extreme noise
  • Improved camera navigation
  • Improved camera transitions with quadratic interpolation function instead of linear
  • Improvement: Environment image is now cleared when loading a new scene
  • Improvement: Removed automatic cycle back to first camera when in "Camera" animation mode
  • Improved UI - removed Modifier key option and include them in navigation preset
  • Improved UI - Shortcuts update according to navigation preset
Project Lavina Beta, v0.2.0
Beta Release
Date - March 12, 2020
New Features
  • Support for opacity maps in "clip" mode. Only bitmaps are supported
  • Separate background option for camera rays instead of the "environment" color/image
  • Importing of Dome light texture as Environment
  • Navigation presets: Max, Maya, Sketchup
  • "Run" when in Free-Look mode
Modified Features
  • Improved rendering of refractive objects on reflective surfaces
  • Improved light cache - it is cleared when a render setting is changed
  • Improved animation experience: Scene, Walkthrough and Cameras mode
  • Improved scene navigation experience
  • Improved status bar
Bug Fixes
  • Fixed denoiser silhouette artifacts
  • Fixed collision enabled only in Free-Look mode
  • Fixed undo action for some local space rotations
