This page gives information about the Self Illumination Render Element.
The Self Illumination Render Element stores the illumination of any self-illuminated materials in the scene. It isolates self-illuminated materials, including V-Ray Mesh Lights, objects with the VRayLightMtl, and any objects with Self-Illumination enabled in their V-Ray material. This render element is useful for brightening or color-correcting self-illuminated materials in the final composite.
For example, the material VRayMtl has a parameter for self-illumination. If this parameter is set to a non-black color value, this render element shows the results of the self-illumination.
VRayVFB – When enabled, the render element appears in the V-Ray frame buffer.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
Common Uses
The Self Illumination Render Element is useful for changing the appearance of self-illuminated surfaces after rendering in compositing or image editing software. Below are two examples of its use.
Original Beauty Composite
Color of self-illuminated surface changed in composite
Intensity of self-illuminated surface reduced in composite
Compositing Formula
The VRaySelfIllumination Render Element is added to the Beauty render to form the final image.
- This element contains only the light geometry itself, not the light emitted from it. Lighting information is contained in the Lighting Render Elements.
