For more information about the individual Scatter parameters, check the Chaos Scatter Details page. The Spline scattering tab allows you to control the number of instances on splines when the 1D scattering mode is set. The Surface scattering tab allows you to control the number of instances and their alignment when the 2D scattering mode is set. The Volume scattering tab allows you to control the number of instances and volume density when 3D scattering mode is set. The video shows the difference between the 2D and 3D scattering modes. |
The Translate tab allows you to control the random positioning of the instances. The Rotation tab allows you to control the random rotation of the instances. The Slope and altitude limit tab allows you to limit the scattered instances to "slopes" at a specific angle or to a given altitude range. The Look at tab allows you to turn scattered objects to specific directions. The Scale tab allows you to scale the instances randomly. The Areas tab allows you to modify affected scattering areas. |
