Camera – Enables transform animation for the imported camera specified in Active Camera. Lights – Enables transform animation for the imported lights. Objects – Enables transform animation for the imported geometry. Materials and Textures – Enables transform animation for the imported materials and textures. Frame interpolation – When enabled, interpolates values between imported frame times. When disabled, animation preview matches the .vrscene frames.
Active Camera – Specifies which camera imported from the .vrscene to use in animation. Only imported cameras from .vrscene file are available for selection. The option is ignored if the Camera Animation track is not empty. The Camera Animation track is used instead in this case.
Add Pause Before – Adds a pause item before the scene animation track. Go To Start – Moves the slider to the start of the scene animation track. Go To End – Moves the slider to the end of the scene animation track. Delete – Deletes the scene animation track. |
