Here are the main components of the Lister. They are available for all tabs: Filters – Filters the objects by Groups, Layers, and Selection sets. Search bar – Searches for an object. You need to enter at least 3 symbols in the field. If a filter is applied, it searches only from the stack with the filtered objects. Options – Offers options for loading, saving and resetting layouts. Loads Layout – Opens the Choose settings file to load window and loads a .vrlst layout file. Save Layout – Opens the Choose saved file destination window and saves the current settings as a layout preset in a .vrlst format. Reset Layout – Resets the layout to its default state. Display options – Opens the Display options dialog where you can add or remove columns and cells. Note that some of the additional columns contain settings that should not be modified as the modifications would have no effect. However, V-Ray provides access to them and you can check their default values. |
Titlebar – All cells except for the first 4 cells can be rearranged. The first 4 cells are always going to stay in the same order. The Name cell is stretchable, while the rest of the cells are not. Statistics for selection – Shows the number of selected objects. Deselect – Deselects all objects. The number of instanced lights or cameras is marked in brackets in front of the object’s name.
Note that the Lights and Cameras tabs can be rearranged by dragging them. |
