Sun (Generic Data) – Specifies the Sun the aerial perspective effect is connected to. Visibility (Number) – Specifies the distance in meters at which the fog has absorbed 90% of the light coming from the objects behind it. Lower values make the fog appear more dense, while larger values reduce the effect of the aerial perspective. Height (Number) – Controls the height of the atmosphere layers in meters. Lower values can be used for artistic effects. Multiplier (Number) – Controls the amount of sunlight scattered from the atmospheric effect. A value of 1.0 is physically accurate. Color (Color) – Affects the color of the unscattered light. |
