Click the Create new Chaos Scatter object ( ) button in the top toolbar. Alternatively, go to the Objects tab in the Right panel, locate the Scene outliner and click the Create new Chaos Scatter object ( ) button. This creates a Chaos Scatter object in the Objects list and displays the parameters of the Scatter object when selected. Go to the Common settings tab of the Details panel. Using the Pick scene object(s) ( ) button, pick a distribute-on target object. You can pick more than one object. The object(s) you picked serves as a surface on which the instances are distributed. Then select an instanced model object using the Pick a scene object(s) ( ) button. You can pick more than one object. The object is then instanced multiple times onto the distribute-on target objects. |
